Topic: Solved !!!Unable to get full power in one direction wrong algorythm? (Read 2027 times) previous topic - next topic
Fabiolus
Aug 06, 2013, 03:27 am Last Edit: Aug 11, 2013, 03:13 am by Fabiolus Reason: 1
Good day,
I am trying to control motors wireless, I am able to transmit the signal and run it through a sketch on the arduino receiving but for some reason when applying the joystick in one direction I cant get full power from the motors. I cant troubleshoot with Arduino Uno via terminal.
So far I have only configure 1 output pin to test the signal going to the xbee/arduino receiving.
Help would be appreciated if you can figure out why one direction is not working properly and the other direction respond correctly
Problem:
https://www.dropbox.com/s/0lyuq6arn5a22rt/VIDEO0106.mp4
xbee series 1 settings
Transmitter xbee settings
ATRE
ATMY1234
ATDL5678
ATDH0
ATID0
ATD02
ATIR64
ATWR
Receiver xbee settings:
ATRE
ATMY5678
ATDL1234
ATDH0
ATID0
ATWR
sketch in Arduino receiving
Code: [Select]
XBeeAnalogReceiveSeries1
Read an analog value from an XBee API frame and set value accordingly.
#include <Servo.h>
int servoVal;
int servoVal2;
Servo ST1, ST2;
 // Servo
 ST1.attach( 6, 1000, 2000);
 ST2.attach(5, 1000, 2000);
configureRadio(); // check the return value if you need error handling
boolean configureRadio() {
// put the radio in command mode:
Serial.flush();
Serial.print("+++");
delay(100);
String ok_response = "OK\r"; // the response we expect.
// Read the text of the response into the response variable
String response = String("");
while (response.length() < ok_response.length()) {
if (Serial.available() > 0) {
response += (char) Serial.read();
// If we got the right response, configure the radio and return true.
if (response.equals(ok_response)) {
Serial.print("ATAP1\r"); // Enter API mode
delay(100);
Serial.print("ATCN\r"); // back to data mode
return true;
return false; // This indicates the response was incorrect.
 if (Serial.available() >= 14) { // Wait until we have a mouthful of data
if (Serial.read() == 0x7E) { // Start delimiter of a frame
// Skip over the bytes in the API frame we don't care about
for (int i = 0; i < 10; i++) {
Serial.read();
// The next two bytes are the high and low bytes of the sensor reading
int analogHigh = Serial.read();
int analogLow = Serial.read();
int analogValue = analogLow + (analogHigh * 180);
servoVal = map(analogValue, 0, 1023, 0, 180);     // scale it to use it with the servo (result  between 0 and 180)
ST1.write(servoVal);                       // sets the servo position according to the scaled value
johnwasser
Code: [Select]
You want:
Code: [Select]
int analogValue = analogLow + (analogHigh * 256);
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
Fabiolus
#2
Aug 07, 2013, 03:29 am Last Edit: Aug 07, 2013, 03:33 am by Fabiolus Reason: 1
Thank you very much it worked  :)
Unfortunately a new problem surfaced, with the changes made the motors are getting signal for some reason but i can control the speed in both direction. After looking with the multimeter I saw that 3.3 volt was sent to the motors, any idea why?
Ill go over everything again, any help is appreciated at this point.
http://youtu.be/DbNDnr-8NRQ
Transmitter xbee series 1 settings
ATRE
ATMY1234
ATDL5678
ATDH0
ATID0
ATD02
ATIR64
ATWR
Receiver xbee series 1 settings:
ATRE
ATMY5678
ATDL1234
ATDH0
ATID0
ATWR
Code: [Select]
Read an analog value from an XBee API frame and set the value accordingly.
#include <Servo.h>
int servoVal;
int servoVal2;
Servo ST1, ST2;
 // Servo
 Serial.flush();
 delay(100);
   delay(100);
   return true;
 else {
       Serial.read();
Fabiolus
UPDATE,
I revised everything and made changes to the transmitter side. I was passing 5volts to the pot before and now I changed and pointed to the 3.3volts which fixed the problem. I can now send X signal from the joystick to the xbee.
Now the ultimate question : is it possible to now do the same for the y signal? I would like ideally to capture both X&Y and transmit.
Thank you
http://youtu.be/fx3SUvI77D4
Fabiolus
Good day,
Finally after many obstacles, faulty wires, wrong code etc... success :smiley-mr-green:.
I present to you communication between 2 arduinos with xbees series 1 with1 joystick passing analog X&Y to other arduino via xbees wireless!!!! All using the EasyTransfer library from Bill Porter http://www.billporter.info/2011/05/30/easytransfer-arduino-library/
This sketch or method can be applied to many different project or other similar controlled bots with minimal coding expertise. I have search and red many books and none come even close to what you are about to see.
I hope you enjoy building your robots and making them controlled wireless.
Pre requisite:
2 xbees series 1 default settings(Out of the box!!) are ok but if you wish you can change the pan id but that is it!!!
1 joystick thumb joystick from ladyaya or equivalent 2 seperate joystick would work.
the way the sketch work you could have a mega arduino and include as much motors/servos/joystick/ button that you wish!!! have fun!!
2 arduino uno board
2 dc motors or servos
9 volts batterie
12/24 volts batterie
http://youtu.be/G-qAB9MzrPU
Please refer to schematic for wiring
Remote control Arduino sketch
Code: [Select]
#include <EasyTransfer.h>
EasyTransfer ET;
const int potpin1 = A0;
const int potpin2 = A1;
struct SEND_DATA_STRUCTURE{
int servo1val;
int servo2val;
SEND_DATA_STRUCTURE txdata;
void setup(){
  //  Serial.begin(115200);
  ET.begin(details(txdata), &Serial);
void loop(){
  int val1 = analogRead(potpin1);
  int val2 = analogRead(potpin2);
  val1 = map(val1, 0, 1023, 0, 180);
  val2 = map(val2, 0, 1023, 0, 180);
  txdata.servo1val = val1;
  txdata.servo2val = val2;
  ET.sendData();
robot Arduino receiving
Code: [Select]
#include <Servo.h>
EasyTransfer ET;
Servo myservo1;
Servo myservo2;
Servo ST1, ST2;
struct RECEIVE_DATA_STRUCTURE{
  int servo1val;
  int servo2val;
RECEIVE_DATA_STRUCTURE txdata;
void setup(){
  // Servo
void loop(){
  if(ET.receiveData()){
    ST1.write(txdata.servo1val);
    ST2.write(txdata.servo2val);
