Topic: Electric grippers (Read 2200 times) previous topic - next topic
Yaro
Hi, i need to create an electric gripper. I don't want to use motors couse the speed of the greep need to be about 2ms. So i tought to use a solenoid that can be real fast, but i found only hydraulic solenoids and big and heavy solenoids. The greep don't need to be real strong but i really need to contain the price. The displacement of the gripper need to be at least 1cm per part(so the solenoid need to do a min 1cm movement). Any ideas? about a better gripper or where to find parts(the name of parts)?
I will really appreciate your help!
Yaro
I tought something like this: (sorry for bad drawings)
or
polymorph
So you need the solenoid to release the stepper?
Steve Greenfield AE7HD
Drawing Schematics: tinyurl.com/23mo9pf - tinyurl.com/o97ysyx - https://tinyurl.com/Technote8
Multitasking: forum.arduino.cc/index.php?topic=223286.0
gammon.com.au/blink - gammon.com.au/serial - gammon.com.au/interrupts
jroorda
Yaro
Yes, something like this. But i can't find (what i need)/price relation.
Have you seen this solenoid?  https://www.sparkfun.com/products/11015
This is really near to what i need, but as datasheet say at 6 mm stroke can generate only 20gf. It's low. Tomorrow i will calculate exact need, but i'm pretty sure that i need is a 10mm of stroke and 200+ gf.
And I correct what i type in the first post, the speed i need is 20 ms not 2 ms.
polymorph
Look for pinball solenoids. They usually require 24V, but are fast and powerful.
zoomkat
Quote
Mouse trap?
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
jroorda
You could potentially build your own.  Its a big electromagnet with a rod in the middle that is sprung one way and is driven the other way by the magnet.  The pushing force is limited by the size and current in the electromagnet.  More turns and more current will equal more power.  A quick Google search for "build a solenoid" should be enough to get you started.
