Topic: Legitimate uses for pointers? (Read 14148 times) previous topic - next topic
tylernt
Aug 15, 2013, 04:05 pm Last Edit: Aug 15, 2013, 04:09 pm by tylernt Reason: 1
I've always read that "real C programmers use pointers" but as of yet, never had a good reason to use them. Then, last night I thought I had an epiphany. I had a function that had to be able to modify one of three variables. Ah, says I, I finally found a reason to use pointers!
Code: [Select]
setup()
 byte red;
 byte green;
 byte blue;
 modifyColor(&red);
 modifyColor(&green);
 modifyColor(&blue);
void modifyColor(byte *color)
 *color++;
But then this morning I realized I could just do
Code: [Select]
blue=modifyColor(blue);
and accomplish the same thing without a pointer. So what advantage is there to pointers?
AWOL
Quote
Code:
Not with that void function you can't.
Arrch
Try to have the function modify three variables.
econjack
The code:
Code: [Select]
works fine, but you'll need two other assignment statements for the other two colors. If you use a pointer, modifyColor() does need to concern itself which color is changed since no return value is needed and the return type can remain void since no assignment statement is needed. Write your code for changing all three colors, one version using pointer and the other without pointers and tell us about the code size.
tylernt
Ok, so,
Code: [Select]
byte modifyColor(byte color)
 color++;
Or,
Code: [Select]
byte red;
byte green;
byte blue;
setup()
 modifyColor(red);
 modifyColor(green);
 modifyColor(blue);
 color++;
Arrch
#5
Aug 15, 2013, 04:22 pm Last Edit: Aug 15, 2013, 04:25 pm by Arrch Reason: 1
 modifyColor(red);
 modifyColor(green);
 modifyColor(blue);
  color++;
Nope. The return values have to be assigned and functions need a return type.
Let me rephrase: try having it modify three colors with a single call to modifyColor().
tylernt
Using global variables: Binary sketch size: 466 bytes (of a 32,256 byte maximum)
Using return value assignment: Binary sketch size: 466 bytes (of a 32,256 byte maximum
Using pointers: Binary sketch size: 466 bytes (of a 32,256 byte maximum)
AWOL
radman
You can use pointers to directly address hardware e.g. registers in a UART.
tylernt
Hm. How would I do that with pointers? I'd have to pass modifyColor(&red, &green, &blue) and deal with each argument inside modifyColor, no?
econjack
Arrch makes a better point. (Indeed, you can write the pointer and non-pointer code and get the same code size...pretty good compiler.) What Arrch is asking is, what if you want to increment all three colors with one function call:
Code: [Select]
modifyColor(red, green, blue);
How do you do that without pointers?
tylernt
Code: [Select]
Make red, green, blue global variables.
Arrch
Which defeats the purpose of having the function in the first place.
radman
You can pass pointers to functions as arguments to functions. I admit I have not used that facility a lot but it can be useful.
tylernt
I guess I still don't understand the benefit of using global variables and modifyColor(red, green, blue) over calling modifyColor three times, once for each color, assigning the return values.
