[code]ok the first code listed is the working code with everything but the lcd screen the second code is the working code for just the ping sensor with lcd screen
I basically merged the two different codes into one and thats when all the problems happened
/*MAEP 2.0 Navigation
by Noah Moroze, aka GeneralGeek
This code has been released under a Attribution-NonCommercial-ShareAlike license, more info at
http://creativecommons.org/licenses/PING))) code by David A. Mellis and Tom Igoe
http://www.arduino.cc/en/Tutorial/Ping*/
#include <Servo.h> //include Servo library
const int RForward = 0;
const int RBackward = 180;
const int LForward = RBackward;
const int LBackward = RForward;
const int RNeutral = 90;
const int LNeutral = 90; //constants for motor speed
const int pingPin = 4;
const int irPin = 0; //Sharp infrared sensor pin
const int dangerThresh = 10; //threshold for obstacles (in cm)
int leftDistance, rightDistance; //distances on either side
Servo panMotor;
Servo leftMotor;
Servo rightMotor; //declare motors
long duration; //time it takes to recieve PING))) signal
rightMotor.attach(5);
leftMotor.attach(6);
panMotor.attach(3); //attach motors to proper pins
panMotor.write(90); //set PING))) pan to center
int distanceFwd = ping();
if (distanceFwd>dangerThresh) //if path is clear
leftMotor.write(LForward);
rightMotor.write(RForward); //move forward
else //if path is blocked
leftMotor.write(LNeutral);
rightMotor.write(RNeutral);
panMotor.write(0);
rightDistance = ping(); //scan to the right
panMotor.write(180);
delay(700);
leftDistance = ping(); //scan to the left
panMotor.write(90); //return to center
delay(100);
compareDistance();
void compareDistance()
if (leftDistance>rightDistance) //if left is less obstructed
leftMotor.write(LBackward);
rightMotor.write(RForward); //turn left
else if (rightDistance>leftDistance) //if right is less obstructed
rightMotor.write(RBackward); //turn right
else //if they are equally obstructed
rightMotor.write(RBackward); //turn 180 degrees
long ping()
// Send out PING))) signal pulse
pinMode(pingPin, OUTPUT);
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH);
delayMicroseconds(5);
//Get duration it takes to receive echo
pinMode(pingPin, INPUT);
duration = pulseIn(pingPin, HIGH);
//Convert duration into distance
return duration / 29 / 2;
[/code]
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
lcd.begin(16, 2);
lcd.print("Hello Jason");
lcd.clear();
lcd.print("Activating KITT");
long duration, inches;
inches = microsecondsToInches(duration);
lcd.print(inches);
lcd.print("in to obstacle");
delay(100);
lcd.clear();
delay(100);
long microsecondsToInches(long microseconds)
return microseconds / 74 / 2;
