Topic: need some help with code (Read 15434 times) previous topic - next topic
MillerJLee98579
i tried that now the screen doesnt print anything and the robot still goes in circles even with a 6 foot clearance between any obstacle
wildbill
In that case I suggest putting the robot up on blocks, attach it to your PC and put in some debugging serial.prints to show you what's going on. Finding out what distance the ping is giving would be a good start. Is there anything on the robot that's close enough to the ultrasonic sensor to cause a reflection?
MillerJLee98579
no there is nothing within 6 feet of the robot
MillerJLee98579
added a serial print commands to see what the ping sensor is seeing and still getting nowhere (nothing is showing up in the serial monitor) seriously what is going on with this code?
/*MAEP 2.0 Navigation
by Noah Moroze, aka GeneralGeek
This code has been released under a Attribution-NonCommercial-ShareAlike license, more info at http://creativecommons.org/licenses/
PING))) code by David A. Mellis and Tom Igoe http://www.arduino.cc/en/Tutorial/Ping
Edited by Jason Miller for Project KITT
#include <Servo.h> //include Servo library
#include <LiquidCrystal.h> //include lcd library
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
const int RForward = 0;
const int RBackward = 180;
const int LForward = RBackward;
const int LBackward = RForward;
const int RNeutral = 90;
const int LNeutral = 90; //constants for motor speed
const int pingPin = 4;
const int irPin = 0;  //Sharp infrared sensor pin
const int dangerThresh = 5; //threshold for obstacles (in cm)
int leftDistance, rightDistance; //distances on either side
Servo panMotor;
Servo leftMotor;
Servo rightMotor; //declare motors
long duration; //time it takes to recieve PING))) signal
  lcd.begin(16, 2);
  lcd.print("Hello Jason");
  lcd.clear();
  lcd.print("Activating KITT");
  lcd.clear();
  lcd.print("KITT Online");
  rightMotor.attach(5);
  leftMotor.attach(6);
  panMotor.attach(3); //attach motors to proper pins
  panMotor.write(90); //set PING))) pan to center
  int distanceFwd = ping();
  if (distanceFwd>dangerThresh) //if path is clear
    leftMotor.write(LForward);
    rightMotor.write(RForward); //move forward
  else //if path is blocked
    leftMotor.write(LNeutral);
    rightMotor.write(RNeutral);
    panMotor.write(0);
    rightDistance = ping(); //scan to the right
    panMotor.write(180);
    delay(700);
    leftDistance = ping(); //scan to the left
    panMotor.write(90); //return to center
    delay(100);
    compareDistance();
void compareDistance()
  if (leftDistance>rightDistance) //if left is less obstructed
    leftMotor.write(LBackward);
    rightMotor.write(RForward); //turn left
  else if (rightDistance>leftDistance) //if right is less obstructed
    rightMotor.write(RBackward); //turn right
   else //if they are equally obstructed
    rightMotor.write(RBackward); //turn 180 degrees
long ping()
  // Send out PING))) signal pulse
  long duration, inches;
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  //Get duration it takes to receive echo
  pinMode(pingPin, INPUT);
  duration = pulseIn(pingPin, HIGH);
  inches = microsecondsToInches(duration);
  lcd.print(inches);
  lcd.print("in to obstacle");
  delay(100);
  lcd.clear();
  delay(100);
  return(inches);
  Serial.print(inches);
  Serial.print("in, ");
  Serial.println();
  long microsecondsToInches(long microseconds)
  return duration / 74 / 2;
wildbill
Move the return after the serial prints. Read up about return, it does two things - specifies the return value, but also exits the function. Your debugging code is never executed.
PaulS
long ping()
Why, when ping() returns a long, is the result stored in an int?
MillerJLee98579
well until i can figure out why this isnt working im either going to give up or buy a premade arduino bot
TomGeorge
I heartily agree, start with small steps, only program the arduino to get the ultrasonic working, forget any programming for any of the other inputs and outputs.
When you have reliable results from the ultrasonic, then setup the piece of code to react to in or out of distance threshold.
Then once that is done , think about motor control, even if you have to do the motor control separately to the ultrasonic and put them together later.
The intro screen stuff can be done last.
If you do it step by step it will minimise errors and help diagnose any conflicts that may occur as you add code.
This may take a lot of time, but in the long term, less frustration and you learn as you go.
Tom
Everything runs on smoke, let the smoke out, it stops running....
MillerJLee98579
ok i still havent figured out why the two codes work seperately but not together no matter how much i try or where i try putting everything in
MillerJLee98579
yeah its driving me nuts been working on this robot since march and getting nowhere with it
MillerJLee98579
RoboProto5.ino: In function 'void loop()':
RoboProto5:57: error: 'ping' was not declared in this scope
this is the error i constantly get in my code yet in the original code this error never shows up
const int pingPin = 7;
const int dangerThresh = 10; //threshold for obstacles (in cm)
Servo panMotor;
Servo leftMotor;
  rightMotor.attach(11);
  leftMotor.attach(10);
  panMotor.attach(6); //attach motors to proper pins
    panMotor.write(0);
    delay(700);
    delay(100);
    compareDistance();
long ping()
  //Convert duration into distance
  return duration / 29 / 2;
#include<Servo.h>
Servo panMotor;
Servo leftMotor;
  lcd.begin(16, 2);
  lcd.clear();
  panMotor.write(90);
  lcd.print(inches);
  delay(100);
  lcd.clear();
  delay(100);
  Serial.println();
    panMotor.write(0);
    delay(700);
    delay(100);
    compareDistance();
  return microseconds / 74 / 2;
the first code posted is the original and the second code posted is the one ive been working on
Jantje
That is because you removed the function ping from the sketch.
And keep away from delay. With your current code the response time of the robot is way above 1 second. That is really slow.
Jantje
Do not PM me a question unless you are prepared to pay for consultancy.
MillerJLee98579
ok fixed the ping function but now my danger thresh hold is not working and neither is my pan servo
#include<Servo.h>
Servo panMotor;
Servo leftMotor;
  lcd.begin(16, 2);
  lcd.clear();
  panMotor.write(90);
    panMotor.write(0);
    delay(100);
    compareDistance();
long ping()
  lcd.print(inches);
  delay(100);
  lcd.clear();
  delay(100);
  Serial.println();
Jantje
go back to http://forum.arduino.cc/index.php?topic=183996.msg1365045#msg1365045
Jantje
