Topic: High level switching with PNP darlington (Read 12319 times) previous topic - next topic
jonh
Quote
and when the starter motor kicks out,
   and you get the 30 volt negative spike from the aulternator,
      what will your darlingtons do then,
Thanks for your help m latest plan is to use bidirectional TVS diode 40 V on main supply to all power :
http://uk.farnell.com/littelfuse/smcj40ca/diode-tvs-40v-1500w-bidir-smc/dp/1827699
mainly to suppress positive spikes but should suppress negative as well although could protect each power transistor with a large series diode do you think this is necessary ? could also use a big inductor if necessary
Quote
OH, and cheap usb car adapters are just that,
    cheap.
i was thinking of using these :
http://www.ebay.co.uk/itm/181005107235?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
to power arduino i though looked quite robust
Do you think P channel MOSFETS will be more robust and forgiving than the darlingtons ? i couldn't really tell from the specs
drjiohnsmith
Hi
large Mosfets are "normally" IMHE more rugged than darlingtons,
    they for one dont have thermal run away, and are a lot lower 'resistance' when hard on,
          and higher resistance when hard off, so assuming fast switching between on and off,
                power dissipation of MOSFETS is also lower than darlingtons.
As for TRV's,
   great things,
      if you have a 12 volt supply, you dont need 40 volt tvs's,
          rate them nearer to the expected voltage,
As for ebay items, from china, you take what u get.
    I have had some fantastic stuff, and I have had some absolute corkers.
         like a unit that is meant to work up to 24 volts input , which had 15 volt input capacitors,
diodes.
  mosfets have an inherent reverse diode in them,
     so if its possible for the supply to the load to go lower than the load voltage, you need a series reverse  current limiter. A diode would suit.
u can take things to extream, depending how 'reliable' fault tolerant you want it,
    remember also, the car shakes quite a bit, so everything needs to be well bolted down so it wont shake loose.
dc42
True, however mosfets are easily damaged by excessive gate-source voltage. Either use an automotive mosfet with integral gate protection diodes (and an appropriate gate series resistor), or add external protection to ensure that the gate-source voltage stays within limits.
As for TRV's,
  great things,
... allowing for the fact that when the battery is on charge, its voltage is nearer 14V than 12V.
diodes.
Not quite sure what you mean there. Typical automotive loads such as lamps don't mind a reverse voltage; but for any that do, a diode is necessary.
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
jonh
thanks everyone will wait and see what arrives from china !! the reason i have done this is that i was getting overwhelmed with trying to work out this type of circuit myself.
the reason i chose the 40v diode was because the darlingtons where ok to 60v and wanted to allow possible 24 v boost
will keep everyone p[osted
jonh
#19
Feb 11, 2014, 08:23 pm Last Edit: Feb 19, 2014, 04:57 pm by jonh Reason: 1
Hi Guys have spent the last 4 months testing the above till i was happy then getting a nice shiney white fritzing board made with 16 of these circuits on one board:
It is working a treat however there is one strange effect that i wanted to get some ideas on  i have yet to put it in the kit car (as we are still building it) so I have been trying it on the kitchen table the problem I get is that when i attach a halogen headlamp to one of the outputs everything goes off for a split second  or so then it all come back on i wondered if this is a power supply problem my power supply is rated to 5A at 16v and this is pushing it as the lamp is rated to 60w (so 5amps at 12v)  the output display on the PSU certainly drops to 9V but no lower than this the arduino is powered separately, is it possible that the lamp when cold draws alot more current and so for a small time the power supply does not output enough current for the other channels even the the current display doesn't go below 9V. If it is likely to be this then i am not worried as the car battery should presumably be happy to manage this all ok, but any thought would be gratefully received.
jonh
some photos of the board if  interested
dc42
#21
Feb 11, 2014, 11:07 pm Last Edit: Feb 11, 2014, 11:09 pm by dc42 Reason: 1
1. Halogen lamps take much more current for a short while when you first turn them on. That is temporarily overloading your power supply.
2.You may have difficulty keeping your TIP125s cool enough if you put 5A through them, even with the heatsinks. Mosfets would normally be used for this application, because they dissipate much less power when switching high currents, so if chosen carefully they would not need heatsinks at all.
jonh
Ok so hopefully when in the car the battery should have the beef to provide the startup current for the halogen lamps. I only have 1 circuit with hologen lamps on it, both the main beams, which would be 10 amps in total which could be on for hours so i plan to use a relay on this  one circuit, all the other outputs are less a than 1 amp so with the heatsinks I think the darlingtons will be ok. I have a voltage drop of about 0.8 - 1 v on the darlingtons which does not led to noticable dimming of any of the lamps, i did read an article that seemed to be saying that darlingtons are more robust in the face of the normal automotive transients etc vs mosfets ?
I also plan to make a mega shield with ruggeduino type protection (zenner + thermister) for all the I/O pins as there does not seem to be a ruggeduino mega ? The power supply for the ardiuno is via a USB power socket designed for car electrics.
thanks for the input all very helpful as usual
drjiohnsmith
we'd all love a ruged arduino mega, but thats not going to happen now.
great to see the board, it looks good.
do your leds have built in current limiting resistors ?
jonh
Why is that not going to happen is there something I've missed .??
And yep all 5v or 12 v LEDs  with built in resistors , I also have swapped the 10k resistor from the arduino output pins into the npn with 1 k as this gave me the smallest v drop across the Darlington so I assume it wasn't saturating the npn and therefore not completely saturating the Darlington with 10k, this means that I could drain potentially 16 x 5 = 80mamps from all output pins which I think is ok ?? Although it would be unlikely that all channels would be on at the same time foggy,breaking,reversing,flashers on, oil leak , pressing horn ,dark etc
Thanks for you help guys
MarkT
All tungsten lighting does this, because the resistance of tungsten increases with
temperature, not unique to halogen.  About 8 times the hot current.
Failing to provide enough current can cause the lamp to stall at a much lower
temperature drawing full supply current but dissipating less than the rated power
because of supply voltage droop.
Quote
80mA for the whole chip is OK.  Chip supply or ground are both limited to 200mA and
various groups of pins have a combined limit of 150mA source, 100mA sink (table 28.1
footnotes in datasheet for more details)
CrossRoads
#26
Feb 13, 2014, 03:20 pm Last Edit: Feb 13, 2014, 03:24 pm by CrossRoads Reason: 1
I had worked up & posted a "hardened" Mega shield, only had interest from 1 person in it, so I didn't make any.
http://forum.arduino.cc/index.php?topic=185501.0
jonh
The hardened mega looks great, i am wanting to connect my power board to the arduino mega via a ribbon cable so i think i will try to make my own on fritzing. Do you know if you can get the ptc's and zenner diodes you have used as through hole parts ? or if not do you think they would be v fiddly to solder by hand ??
CrossRoads
Not available as leaded parts.
Very small sizes selected to fit the space selected.  I could not place that many by hand without issues.
jonh
ok i have decided for now just to focus on protecting  my input pins as these will connect to switches all over the car which could potentially get connected to 12 v by mistake etc etc. My output pins are reasonable sfe as they connect via 1k to the board and and then to a npn base.
I was planning to use an optocoupler for each of the 16 input pins with 4 of these 4 ch optocouplers:
http://www.vishay.com/optocouplers/list/product-83526/
and drive the led side from the 12v supply on the power board as each input needs >20mA so would overload the 5v arduino pin,this is my plan:
any comments on whether this would work greatfully received and also whether i am right about not worrying so much about my output pins?
Also i plan to try using a p channel mosfet as a reverse voltage (connect the car battery round the wrong way ) protection for the whole setup.
