Topic: [Solved] Arduino Control 16MB SD Card (Read 1 time) previous topic - next topic
Gigi10012
Sep 03, 2013, 05:21 pm Last Edit: Sep 03, 2013, 05:53 pm by Gigi10012 Reason: 1
Hello,
I Have 16MB SD Card. I want to write data to SD card. i uploaded ReadWrite code to Arduino UNO but
it said: "Initialization Failed". Then I uploaded card info sketch. it said:
Code: [Select]
Initializing SD card...Wiring is correct and a card is present.
Card type: SD1
Volume type is FAT12
Volume size (bytes): 14848000
Volume size (Kbytes): 14500
Volume size (Mbytes): 14
Files found on the card (name, date and size in bytes):
The Problem is that My SD Card Volume type is FAT12 but SD Card Library only supports FAT16 and FAT32 SD Card Volume types.
My Question is that:
Is there any library to control FAT12 SD Card?
or
How to Change My SD Card Volume type from FAT12 to FAT16 using Windows 7 or Arduino (is it possible to format SD Card using Arduino and Change Volume Type from FAT12 to FAT16)?
Check out My Youtube Channel:
http://www.youtube.com/GigiButbaia
fat16lib
Quote
SD.h does not support FAT12.  The standard format for cards 16 MB and smaller is FAT12.
SdFat has a formatter, the SdFormatter example, which will format a 16 MB card FAT16.
It is also possible to enable FAT12 support with SdFat but FAT12 support has not been well tested.
Gigi10012
