Topic: servo code (Read 4027 times) previous topic - next topic
Ghostbusters
with the Sparkfun inventor kit there is a circuit that controls a single servo with arduino. based on this code i want to build a robot, But i am having trouble understanding the underlined part of the code  at the very bottom
SparkFun Inventor's Kit
Example sketch 08
Servo servo1;  // servo control object
  // We'll now "attach" the servo1 object to digital pin 9.
  // If you want to control more than one servo, attach more
  // servo objects to the desired pins (must be digital).
  // Attach tells the Arduino to begin sending control signals
  // to the servo. Servos require a continuous stream of control
  // signals, even if you're not currently moving them.
  // While the servo is being controlled, it will hold its
  // current position with some force. If you ever want to
  // release the servo (allowing it to be turned by hand),
  // you can call servo1.detach().
  servo1.attach(9);
  int position;
  // To control a servo, you give it the angle you'd like it
  // to turn to. Servos cannot turn a full 360 degrees, but you
  // can tell it to move anywhere between 0 and 180 degrees.
  // Change position at full speed:
  servo1.write(90);    // Tell servo to go to 90 degrees
  delay(1000);         // Pause to get it time to move
  servo1.write(180);   // Tell servo to go to 180 degrees
  servo1.write(0);     // Tell servo to go to 0 degrees
  // Change position at a slower speed:
// To slow down the servo's motion, we'll use a for() loop
  // to give it a bunch of intermediate positions, with 20ms
  // delays between them. You can change the step size to make
  // the servo slow down or speed up. Note that the servo can't
  // move faster than its full speed, and you won't be able
  // to update it any faster than every 20ms.
  // Tell servo to go to 180 degrees, stepping by two degrees
  for(position = 0; position < 180; position += 2)
    servo1.write(position);  // Move to next position
    delay(20);               // Short pause to allow it to move
  // Tell servo to go to 0 degrees, stepping by one degree
  for(position = 180; position >= 0; position -= 1)
Jantje
The sparkfun kit comes with lots of documentation and this is extremely well documented code. So I really wouldn't know what to add.
Do not PM me a question unless you are prepared to pay for consultancy.
zoomkat
#7 below would be a good place to start.
http://forum.arduino.cc/index.php/topic,148850.0.html
Ghostbusters
I THINK I NEED TO REPRASE THIS QUESTION. MY NEW QUESTION IS, WITH THE UNDERLINED CODE I DONT UNDERSTAND THE CODE AND WHAT MEANS WHAT TO ARDUINO. I AM MAKING A ROBOT AND I WANT TO USE SERVOS, HOWEVER THAT UNDERLINED CODE IS WHAT CONTROLS SPEED BUT I DONT UNDERSTAND HOW TO CONTROL THE SPEED WITH THAT CODE FORMAT. I HOPE YOU CAN UNDERSTAND MY QUESTION THANKS IN ADVANCE
AWOL
I THINK I NEED TO REPRASE rewrite THIS QUESTION without all the shoutiness.
Ghostbusters
sorry i didnt realize caps lock was on :smiley-red:
zoomkat
Below is the servo sweep example from the arduino IDE. There is a delay between the small servo moves so the overall movement of the servo is slowed down.
// Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
JimboZA
What your undelined code is doing is going from 0 to 180 in steps of 2 degrees... Each servo1.write(position) is 2 degrees further than the last write, since the for's position += 2 is incrementing in 2's. (Zoomcat's is similar, but in 1's). BUT, each pass through the for also includes a delay(20) (or 15 in zoomcat's example) which causes a pause of 20ms between each 2 degree movement step.
See here to read up on how "for" works.
Without that loop and delay, if the servo was at say 0 degrees and you sent it a servo1.write(180) it would have gone from 0 to 180 as fast as it was able. Servo speed is quoted by the makers as the time to move through 60 degrees, such as 0.16 seconds for this one. (That's the speed with no load, obviously slower when it's trying to move something.)
HTH?
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
Ghostbusters
thanks guys you are awsome
