Topic: UDP supported? (Read 28416 times) previous topic - next topic
sonnyyu
At Yun:
Code: [Select]
nano /mnt/sda1/udp.py
Code: [Select]
#!/usr/bin/python
import socket
UDP_IP = "192.168.0.230"   #Mac or Linux box's IP
UDP_PORT = 8888
MESSAGE = "G"
sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM) # UDP
sock.sendto(bytes(MESSAGE), (UDP_IP, UDP_PORT))
sock.close()
Code: [Select]
chmod 755 /mnt/sda1/udp.py
At Linux/Mac box( wait to call):
Code: [Select]
nc -ul 192.168.0.230  8888
At Yun:
Code: [Select]
/mnt/sda1/udp.py
If every thing is OK( Mac Box got "G"), then  change UDP_IP = "Uno IP address", test it again.
Now is time make Arduino of Yun to call "/mnt/sda1/udp.py"
Code: [Select]
String cmd = "/mnt/sda1/udp.py";
richard47
Thank you for taking the time to help me. You have certainly given me a lot to think about.
I understand the procedure that you have set out but I still need to sort out how to implement the various bits of code but I will try.
Many thanks,
Richard
richard47
Thank you for putting me on the right track  :) I am now able to control my Wi-Fi lights from the Yun.
I have learnt a lot with your help.
However, I am missing one feature now. Some of my UDP commands have replies and I would like to retrieve them. I think that I can modify the Python script to get the reply but how do I pass the reply back to the Arduino side of the Yun?
sonnyyu
Did you like try this?
Code: [Select]
recvmsg=sock.recv(1024)
#print recvmsg
sock.close()
richard47
#19
Mar 23, 2014, 06:01 pm Last Edit: Mar 23, 2014, 06:03 pm by richard47 Reason: 1
Code: [Select]
#print recvmsg
sock.close()
I have just modified the Python code to include
#print recvmsg
and I still do not get a reply sent across to the Arduino side of the bridge. What does #print recvmsg do?
sonnyyu
uncomment  "#print recvmsg" for debug code at Yun console.
The code send reply back to Yun:
Code: [Select]
import sys
sys.path.insert(0, '/usr/lib/python2.7/bridge/')
from bridgeclient import BridgeClient as bridgeclient
bc = bridgeclient()
bc.put('to_arduino',recvmsg)
richard47
I'm sorry but I don't understand what the complete Python code should be now.
Please would you post the complete code for me.
Regards,
Richard
sonnyyu
At Yun:
Code: [Select]
Code: [Select]
#!/usr/bin/python
import socket
UDP_IP = "192.168.0.230"   #Uno IP address
UDP_PORT = 8888
MESSAGE = "G"
print recvmsg
sock.close()
Code: [Select]
/mnt/sda1/udp.py
make sure return value from nano.
Code: [Select]
#!/usr/bin/python
import socket
import sys
UDP_PORT = 8888
MESSAGE = "G"
#print recvmsg
sock.close()
bc = bridgeclient()
richard47
Thank you once again. I have tried your code that uses the Yun Bridge and it works. I am using it to control my Wi-Fi lights and to retrieve the reply sent by the Uno controlling them.
Without your help I would have given up long ago. I have learnt a lot about the Yun with your help.
Regards,
Richard
esbjerg
Hey, been following this trying to get it to work, and I think I'm very slowly understanding this.
I've got
to run, and that's to edit a file on the sd card right? To do that I need to use
export TERM='xterm-color'
To stop the error
Error opening terminal: xterm-256color.
So it opens fine, but when I try and write the next line of code I get
[ Error writing /mnt/sda1/udp.py: No such file or directory ]
Have I just done something really silly somewhere?
Thanks!
John
sonnyyu
#25
Mar 25, 2014, 02:35 am Last Edit: Mar 25, 2014, 02:37 am by sonnyyu Reason: 1
Code: [Select]
vi /etc/profile
export TERM=xterm-colo
exit ssh then relogin
https://forum.openwrt.org/viewtopic.php?id=13230
Plan B:
Start from fresh (backup your own file!):
Code: [Select]
/usr/bin/reset-to-factory-anyway
reboot
esbjerg
If I try
Code: [Select]
vi /etc/profile
I get
Code: [Select]
#!b/in/sh
rt TERM=xterm-colo
[ -f /etc/banner ] && cat /etc/banner
export PATH=/bin:/sbin:/usr/bin:/usr/sbin
export HOME=$(grep -e "^${USER:-root}:" /etc/passwd | cut -d ":" -f 6)
export HOME=${HOME:-/root}
export PS1='\u@\h:\w\$ '
[ -x /bin/more ] || alias more=less
[ -x /usr/bin/vim ] && alias vi=vim || alias vim=vi
[ -z "$KSH_VERSION" -o \! -s /etc/mkshrc ] || . /etc/mkshrc
[ -x /usr/bin/arp ] || arp() { cat /proc/net/arp; }
[ -x /usr/bin/ldd ] || ldd() { LD_TRACE_LOADED_OBJECTS=1 $*; }
I /etc/profile [Modified] 2/16 12%
and every time i enter it increases both sides by 1, 3/17 etc
And I'm still getting the error no file or directory.
Thanks!
sonnyyu
esbjerg
That was after trying plan b.
sonnyyu
#29
Mar 25, 2014, 05:00 pm Last Edit: Mar 25, 2014, 05:03 pm by sonnyyu Reason: 1
Post
Code: [Select]
uname -a
Code: [Select]
vi /etc/profile
modify file:
Code: [Select]
