Topic: Small battery with 50mA output, does it exist? (Read 9059 times) previous topic - next topic
Archelon
Hello once again Arduino folks!
I wonder if there is any small battery, size between coin cell CR2032 batteries and an AAA-battery, with a voltage around 3V or higher with a possible output current of 50mA?
I need a really small battery which can power an XBee, not for a very long time but a couple of seconds.
The battery doesn't need to have a very long lifetime but at least a couple of minutes.
Thanks for your help!
Archelon
cmagagna
How about a 123A, like they use in (some) LED flashlights?
Archelon
thanks! do you know if there's any smaller batteries with almost the same capacity? 'cause its just a litle to big :/
thanks again!
Erni
Maybe this one
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=7567
Archelon
#4
Sep 11, 2013, 10:03 pm Last Edit: Sep 11, 2013, 10:07 pm by Archelon Reason: 1
Maybe this one
That one look like it's just the right size!
The questions are,
can I pull at least 50 mA out of it?
What is the voltage of that battery?
Considering the battery is used for helicopters with motors and so on it should work right?
Thanks again!
int2str
#5
Sep 11, 2013, 10:07 pm Last Edit: Sep 11, 2013, 10:09 pm by int2str Reason: 1
The RC battery has a "C" rating of 20. Meaning you can draw up to 20x100mA from it, which is 2A (!!).
Obviously it's not going to last long, but 50mA will be no problem at all.
Single LiPo cells are rated at 3.7V. In reality, 4.2V fully charged and I wouldn't discharge past 3.7V to be safe.
Erni
Quote
Fully charged it will be 4.2V.
Archelon
#7
Sep 11, 2013, 10:27 pm Last Edit: Sep 11, 2013, 10:29 pm by Archelon Reason: 1
Woow 2A thats alot, so if I only need 50mA to my XBee which I will power, will the battery force more current into the circuit than that?
If my circuit only draw 50mA won't the battery last a little bit longer?
To be safe of what? That it will work?
Quote
Thanks guys!
One more newbie questions since you seem to know these things about singe cell LiPo batteries.
How do I charge that battery since its a rechargeable?
Thanks! I promise to post a picture of the project I am working on if I can get it to work(Installing a remote in a lighter)
int2str
No, that's not how it works. :)
That's just the maximum discharge rate. The XBee will only draw the current it needs.
Quote
The battery is rated at 100mAh. So if you're drawing 50mA continuous, it would last for 2 hours.
LiPo batteries do not like to be deep discharged. If you completely discharge the battery, you risk a fire.
Quote
You need a LiPo charger.
http://www.amazon.com/Heli-Max-Charger-Novus-CX-LiPo/dp/B00272WUFC
retrolefty
Quote
I don't believe that is true. LiPo can suffer fire damage from overcharging or over current draw if no protection device(s) are used, but overdischarge just causes a cell failure such that it will no longer except a new charge, but not fire damage.
Lefty
int2str
Sorry, yes, you're absolutely correct.
polymorph
Ohm's Law. It isn't just a good idea, it's the law.
Regarding mAhr vs rate of current draw: most rechargeables seem to be rated at the total mAhr when the current draw is sufficient to cause 10 hours discharge time. When higher current is drawn, the mAhr capacity drops. So that 100mAhr cell might only last 1-1/2 or 1-3/4 hours at 50mA draw.
However, if 50mA is drawn intermittently, you may get something closer to the mAhr rating. Not sure.
Steve Greenfield AE7HD
Drawing Schematics: tinyurl.com/23mo9pf - tinyurl.com/o97ysyx - https://tinyurl.com/Technote8
Multitasking: forum.arduino.cc/index.php?topic=223286.0
gammon.com.au/blink - gammon.com.au/serial - gammon.com.au/interrupts
Archelon
Quote
Quote
How do you know when to stop charging, does the chargers have some kind of indicator?
It seems like that kind of battery is sold out everywhere I look do you have any tips on where I could get some of 'em?
Thanks for the information guys! (:
fungus
Hopefully it has an Arduino in it to stop charging when the voltage reaches a cut-off point.
Similarly discharge - cut the power when you reach a certain voltage, don't drain it completely (I believe those batteries should be kept inside the 20%-80% charge range).
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
Grumpy_Mike
#14
Sep 12, 2013, 08:50 am Last Edit: Sep 12, 2013, 06:52 pm by Grumpy_Mike Reason: 1
Quote
Good point. There are various methods.
Charge for a fixed time based on the charge current and mAh rating.
Monitor the temperature of the battery and stop when it starts to rise.
Charge until the charging current drops.
But you have to apply the right technique for the appropriate type of battery.
