Hi I am using an arduino uno stacked with a motorshield. Problem is I couldn't get both motors to work together. Example forward right or backwards left. It also gives off a buzzing sound when I programmed it to move 2 dc motors at the same time. Why?
It doesn't complain when only 1 DC motor is rotating. please advise.
Motor Shield 2-Channel DC Motor Demo
by Randy Sarafan
For more information see:
http://www.instructables.com/id/Arduino-Motor-Shield-Tutorial/
//Setup Channel A
pinMode(12, OUTPUT); //Initiates Motor Channel A pin
pinMode(9, OUTPUT); //Initiates Brake Channel A pin
//Setup Channel B
pinMode(13, OUTPUT); //Initiates Motor Channel A pin
pinMode(8, OUTPUT); //Initiates Brake Channel A pin
void loop(){
forward();
stopping();
revright();
// reverse();
delay(5000);
stopping();
void forward() {
//Motor A forward @ full speed
digitalWrite(12, HIGH); //Establishes forward direction of Channel A
digitalWrite(9, LOW); //Disengage the Brake for Channel A
analogWrite(3, 255); //Spins the motor on Channel A at full speed
void stopping() {
digitalWrite(9, HIGH); //Engage the Brake for Channel A
digitalWrite(8, HIGH); //Engage the Brake for Channel B
void revright() {
digitalWrite(13, HIGH); //Establishes backward direction of Channel B
digitalWrite(8, LOW); //Disengage the Brake for Channel B
analogWrite(11, 200); //Spins the motor on Channel B at half speed
digitalWrite(12, LOW); //Establishes forward direction of Channel A
analogWrite(3, 55); //Spins the motor on Channel A at full speed
void reverse() {
