Topic: Guide to Setup Streaming Web Cam on the Yun (Read 96081 times) previous topic - next topic
Hasr
Is there a way to add a button on a webpage to start/stop the stream? Like a reset button... I want to send a command line to the yun via browser but I have no idea how to do it...
sonnyyu
#76
May 15, 2015, 06:25 pm Last Edit: May 15, 2015, 06:45 pm by sonnyyu
Code: [Select]
nano /www/cgi-bin/mjpg-restart.cgi
Code: [Select]
#!/bin/ash
/etc/init.d/mjpg-streamer restart
echo "Content-type: text/html"
echo ""
echo "Restart..."
exit 0
Code: [Select]
chmod 755 /www/cgi-bin/mjpg-restart.cgi
http://arduino.local/cgi-bin/mjpg-restart.cgi
Code: [Select]
nano /www/webcam/stream.html
Code: [Select]
<form action="http://arduino.local/cgi-bin/mjpg-restart.cgi" method="get" target="_blank">
    <input type="submit" value="Restart">
</form>
http://arduino.local:8080/stream.html
substitute start,stop  for restart if you needed.
Hasr
#77
May 18, 2015, 11:55 am Last Edit: May 18, 2015, 04:58 pm by Hasr
When I try to submit over the html page I get the following: "Access to this resource is forbidden"
EDIT: Forgot to "chmod 755 ..." I'ts working fine now. Thanks!
EDIT2: Is there a way to autoclose the new tab that opens with that form?
Hasr
Solved it with this :)
Code: [Select]
Code: [Select]
<form action="http://arduino/cgi-bin/mjpg-restart.cgi" method="get" target="_self">
</form>
and
Code: [Select]
Code: [Select]
#!/bin/ash
echo
echo "<html><head><meta http-equiv='refresh' content='0;URL=http://arduino:8081/index.html' /><title>Stream Restart</title></head><body><center><p>Restart in 10 seconds...</center></body></html>"
/etc/init.d/mjpg-streamer stop
sleep 10s; /etc/init.d/mjpg-streamer start
exit 0
Stops the stream for 10 seconds and redirects to the stream page after the stream "break"
I want this because I'm worried about overheating the Arduino Yun. Anyone having problem keeping the board running 24/7? I'm waiting for a Keyes L9110 Fan Module to help cooling the precessor...
sonnyyu
Code: [Select]
Code: [Select]
</form>
and
Code: [Select]
Code: [Select]
#!/bin/ash
echo
exit 0
Great work.
sonnyyu
http://forum.arduino.cc/index.php?topic=324160.0
Opeth
Hello,
I have also managed to make my camera stream, but I stucked and I need an answer.
Every time I want to start the mjpg_streamer, I have to connect via SSH to start it, but I have an Android controlled car which is powered by a Power Bank and I don't know how to start the mjpg_streamer.
Is there any command I can write so that when I power the Arduino Yun the mjpg_streamer to start automatically, like in Windows start-up?
Thank you,
Waiting for your feedback.
tedzzzzzz
hi Guys! i hope someone is still active to help me :'(
i'm really having trouble with my camera not taking pictures. i tried everything but still nothing
--- Opening /dev/video0...
Trying source module v4l2...
/dev/video0 opened.
No input was specified, using the first.
Adjusting resolution from 384x288 to 352x288.
--- Capturing frame...
VIDIOC_DQBUF: No such device
No frames captured.
i can't proceed anymore with my project. this is my first arduino project.so everything is very confusing to me.,please help :(
Gl1der
Tested and working a charm. Video streaming smoothly at 5fps 640x480 resolution.
Well done mate.
If anyone else is interested. I would suggest using this build of mjpg-streamer over ffmpeg and ffserver as the throughput is much faster.
Instructions are below. Credit to fibasile for the binary upload of mjpg-streamer:
 Join your Yun to your WLAN
- SSH into OpenWRT via the IP or via arduino.local hostname
- Check your camera's compatibility (some are UVC, some are GSPCA, some not supported at all). I would suggest taking a look here: http://wiki.openwrt.org/doc/howto/usb.video. At this time only UVC driver camera's are supported
- Install either the UVC driver (if not already installed) e.g. opkg install kmod-video-uvc
- Plug your camera into usb slot (type dmesg to see if your camera is detected and drivers working correctly). I used a Microsoft LifeCam HD-3000
- add your micro sd card (it should appear as /dev/sda1 by default)
- Create a folder or mount point /mnt/sda1 (mkdir /mnt/sda1)
- mount your sd card - mount /dev/sda1 /mnt/sda1
- use wget to download the mjpg-streamer binary ( you cant use it with drop box as it redirects to https. This module is not installed by default). I have uploaded it here for convenience : http://www.custommobileapps.com.au/downloads/mjpg-streamer.ipk
- install the package (I installed it in my root folder ~) - opkg install mjpg-streamer.ipk
- View the config options here - http://wiki.openwrt.org/doc/howto/webcam. I just ran it with the following command
Code: [Select]
mjpg_streamer -i "input_uvc.so -d /dev/video0 -r 640x480" -o "output_http.so -p 8080 -w /mnt/share"
 (/mnt/share is my sd card). You can also set it to start upon boot
- Open your web browser to: http://arduino.local:8080/?action=stream for a stream or http://192.168.1.1:8080?action=snapshot for a single snappy
- Enjoy
I know it has been a long time since this was posted but I just tried it today (1/29/2017) and it works great!  So much easier and quicker!  Thanks a million!
zamar10
Hi Daniel,
I´m working in something like what you do. The idea is to take photos an instead of storage the information in a SD card, transfer directly to a PC.
To do this, I'm using an Arduino Yun.
Can you help me? I don't know how to do it.
Thanks a lot.
