Topic: remote upload and remote monitor (Read 4730 times) previous topic - next topic
Jantje
Is there any information on how the remote upload and monitor work?
I noticed it the com ports are not known on the system. Is the rxtx dll still used or is there a swap of technology?
In short:
I would like to implement the same thing in my eclipse plugin but I have no clue where to get started.
Best regards
Jantje
Do not PM me a question unless you are prepared to pay for consultancy.
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
fibasile
#1
Sep 19, 2013, 02:39 am Last Edit: Sep 19, 2013, 02:41 am by fibasile Reason: 1
I don't know about the discovery, but the upload and flashing I think is done via ssh (that's why it asks for the root password i believe).
Flashing is done in two steps: first calling /usr/bin/merge-sketch-with-bootloader.lua with the plain sketch hex file, which gets patched with the bootloader.
Then calling  /usr/bin/run-avrdude <path to the new  hex file> -v -v -v -v
So you get verbose output
federicofissore
Confirm. we use jsch, a pure java implementation of SSH
Jantje
It starts to make sense to me.
So basically the monitor works very much the same as the telnet implementation I use for the arduino connected to the USB as I describe here http://blog.baeyens.it/#post11
I'm still missing some dots but it all starts to make sense.
Best regards
Jantje
federicofissore
It connects via SSH and starts telnet, exactly as described here
http://arduino.cc/en/Guide/ArduinoYun#toc17
Jantje
Because the pieces of the puzzle are not all there yet with me it is hard to know where to find the info.
For me for instance it is confusing that serial monitor is now console. I accept the serial monitor is technically something different but functionally it is the have the same name. After all I'm using the serial monitor to connect to the console  8)
One of those things I still don't get is how the limino is communicating with the Arduino. I mean the doc states it is over the serial port pin 0 and 1 on the Arduino.
But on the linux side I do not see the serial port. My first guess was ttyATH0 was the port but I couldn't get anything to work.
The verbose upload does not show the avrdude command that is started. The logging does show
Code: [Select]
Using Port                    : unknown
I need to look at telnet to see whether it can help me out with the communication I want between limino and Arduino.
Best regards
Jantje
federicofissore
Upload via wifi moves the sketch on the board via SSH than uses avrdude that flashed the sketch via gpio (that's why the sketch is merged with the bootloader: it's like flashing the board with an external programmer)
The sketch and linux communicate via ttyATH0, that's the serial terminal linux exposes and which is connected to the 32u4
Jantje
thanks Federico
I'll try again with ttyATH0 to see whether I get it to move ;-)
best regards
Jantje
