Topic: Mystery component on Yun board? (Read 45650 times) previous topic - next topic
sonnyyu
What about people saying that it woud for after a number of cycles?
What do you mean?
sonnyyu
The connector is designed for semi permanent application. It mean once connect it and leave it.
sonnyyu
Friis Transmission Formula with Propagation Law
  • R = Maximum range for communication link
  • N = Propagation Law (N=2 for line-of-sight, N=4 for urban environments)
  • PT= Transmit power
  • GT= Total antenna gain
  • ? = Wavelength
  • PR= Receiver sensitivity
  • FM= Fading margin
To complete Friis Transmission Formula;-
  • Increase receiver sensitivity, by change AR9331 with higher receiver sensitivity chip set
  • Add RF power amplifier to increase Transmit power which like  a lot of routers
  • Use low frequency, Increase Wavelength
Above is for FYI only.
sonnyyu
FYI;-
People make 2 Openwrt base AR9331 with high gain antenna nodes on 1 mile distance  wells communications.
Just Give Me Antenna and I'll Show You the World!
sonnyyu
pete_dl
I have managed to successfully attach an external antenna to the Yun, but it is a hack.
I had misread this thread, bought a "SMA Female Plug to IPX U.FL Female Pigtail Cable" ( http://www.ebay.co.uk/itm/231098912466) , connected it to the Yun and saw no improvement.
Under a microscope, I could see that both the socket and plug were female. (see attached photos).
As I had nothing to lose, I thought I would have a go at creating a pin that would bridge the two female connectors. 1/0.6mm solid core wire fitted snugly in both connectors. I guessed at the correct length. Luckily i seemed to judge it about right and the plug is held firmly on the socket.
Amazingly, it worked. The Yun seems to auto sense the stronger signal. With no antenna connected to the SMA connector, the signal strength was about 35%. With the antenna connected, it bumped up to about 80%. I plugged/unplugged it a handful of times to convince myself it was working.
Obviously, with no soldering, this is might not be the most reliable of connections.
I would be interested to know from an RF expert whether I have managed to fluke a solution or whether the RF signal can jump the gap of a "not great" connection.
Let me know if you can reproduce my results.
Pete.
sonnyyu
#21
May 08, 2015, 04:44 pm Last Edit: May 08, 2015, 04:48 pm by sonnyyu
Custom made connector:
original murata connector, price not working( $80) and height is not. I got customer engineer drawing done. but  MOQ is too high. plus Intellectual property?
Case to hold custom made connector.
ShapeShifter
Wow. Interesting solution, but it costs more than the Yun! No wonder you didn't go into production.
It's a bit of a hack, but I think Pete's solution is much more practical.
I'm not an RF engineer (as far as I'm concerned, RF is black magic!) but while I'm sure that the "not great gap" is introducing some reflections that may affect signal quality, it's hard to argue with the success you're reporting.
Does anybody know if there's a way for the Yun to report signal quality (or signal/noise ratio) in addition to signal strength?
sonnyyu
$80 is murata price, I got quota about few $ for 10K MOQ. I don't need 10K for my single Yun.  :smiley-money:  Plus It might be  murata  Intellectual property?
sonnyyu
Code: [Select]
iw dev wlan0 survey dump
Survey data from wlan0
        frequency:                      2412 MHz
        noise:                          -95 dBm
        channel active time:            105 ms
        channel busy time:              36 ms
        channel receive time:           35 ms
        channel transmit time:          0 ms
ShapeShifter
Code: [Select]
        noise:                          -95 dBm
Thanks! This would be the interesting number to see with Pete's "imaginative" adapter. But of course, to really know if it's significant, it would need to be compared to the noise figure for a a "proper" adapter...
Still, it would be interesting to see Pete's noise figure with and without the external antenna.
sonnyyu
#26
May 12, 2015, 06:40 pm Last Edit: May 12, 2015, 06:51 pm by sonnyyu
They are completely incompatible with the U.FL type.... No amount of forcing, twisting or whining is going to get these to mate.
http://forum.arduino.cc/index.php?topic=188976.msg1574902#msg1574902
The top connector inside have to build in with forcing to connect well  & cut off build in antenna.
Bournetoride
I have replaced the original outlet with one that will mate with any ordinary antenna lead.
I have mounted my Yun + sensor shield in an old wireless router case, using the antenna giving me good house wide connection
I am not an R.F. engineer but can solder with a magnifying loupe to my eye, requires a steady hand
sonnyyu
Those connector works fine with following limitations:
  • void warranty
  • require handyperson
  • lost auto switch between int/ext antenna
thataintworking
Here's an article on how these work:
http://www.murata.com/articles/ta0791.pdf
These are for test...Not intended to be used as a permanent connector for range extension. You may get lucky. It is rated at 100 cycles max.  (Remember they probably used a number of these cycles during manufacturing.)
What does "rated at 100 cycles max" mean?
