Topic: HttpClient example (Read 5733 times) previous topic - next topic
magi2556
I received new Arduino Yun and it works perfectly.
The examples in local Wifi run well.
HttpClient example don't run with Vodafone internet key wifi, what  I've forgotten ?
Thanks
Marco
Federico_Vanzati
Can you explain better what is it the "Vodafone Internet key wifi" and how you have connected it to the Yun or on the contrary, the Yun is connected to it?
F
magi2556
Vodafone internet key wifi is a GSM modem for connecting to internet as three wifi devices (pc - phone..)
I have yun connected to the pc with USB, I open serial monitor and nothing appears.
It is evident that I am not expert
federicofissore
Have you configured the yun to connect to the wifi provided by the vodafone internet key?
magi2556
No, I need help, thanks.
federicofissore
If you don't configure the yun so that it's able to access the internet, the httpclient example won't work
I suppose this vodafone internet key exposes a wifi connection: you want to use its parameters to configure the yun
If instead it does not expose a wifi connection and you don't have a home wifi, you need to plug in an ethernet cable, just like your computer
Federico_Vanzati
http://arduino.cc/en/Guide/ArduinoYun
on this page you'll find all the information you need to get started with the Yún.
F
magi2556
Scusate l' italiano ma non credo che un po' di polemica all' italiana interessi a livello internazionale.
Ho premesso che sono poco esperto (aggiungo di tutto) e aggiungo anche che sono entusiasta di ARDUINO perchè pur come tale mi ha permesso di fare interessanti esperienze.
Sono tre giorni che leggo e rileggo la Guide segnalata ma data la mia ignoranza non sono riuscito a collegarmi ad internet e non so come utilizzare il suggerimento " I suppose this vodafone internet key exposes a wifi connection: you want to use its parameters to configure the yun".
Segnalatemi la sezione del Forum (se esiste) dove posso ricevere aiuto passo passo (magari in italiano).
Grazie e scusate ma dopo tre giorni si diventa irrascibili.
federicofissore
#8
Sep 20, 2013, 06:31 pm Last Edit: Sep 20, 2013, 06:33 pm by Federico Fissore Reason: 1
Hi magi2556
sorry to read your frustration. Let's restart ok?
Are your trying the HTTPClient example after having plugged your Vodafone internet key INTO your yun? That will NOT work, at least not without (too) much work. That key is a modem and it needs much configuration and extensive googling to set it up.
The yun requires either a wifi access point or a wired ethernet cable. I suppose you have internet at home: do you also have a wifi router? If not, you need to plug your yun to an ehternet wire
magi2556
I finally configure the yun so that it's able to access Vodafone wifi net, the httpclient example works.
I was confused :"Configure a wireless network" with the wireless name filled into the form with "AccessPoint".
http://arduino.cc/en/uploads/Guide/YunWebConfig.png
It would be better:  vodafone-1234, alice-12345,...........
federicofissore
Great news! Thank you for spotting the misunderstanding: we'll update that image
