I'd like some feedback on the attached design. The purpose is to power a peltier chip, via the n-Channel MOSFET, but I want to make sure I don't mess up the wiring and damage my Arduino board. Am I missing any components, maybe a diode between the + and - on the peltier chip incase it generates a current while the system is off?
Here are a few points:
I have a 14.8V input
IC2 is a 6V regulator, which powers the Arduino board
The peltier chip must receive 14.8 V @ 2A - 7A (or there about)
How often are you turning on and off the Peltier device?
The Peltier device will not produce enough voltage to do any harm the the MOSFET.
If your only turning the device on an off once in a while (to maintain a temperature) your diagram looks fine. Just make sure the Peltier device is thermally connected properly. They can not withstand high internal temperatures.
Thank you for everyone for your replies,
I'm making a camping fridge and have a heat sink on it.
The software will turn it on and off based on the temperature - so not often (or in short time).
I forgot about the resistor blush.
I already have a regulator for the arduino board that works @ 6v.
