Topic: Pinout Yun (Read 12968 times) previous topic - next topic
GuggHerr
I have created a pinout diagramm based on the schematic. Please note, I haven't got a board yet, so it could be possible that the order isn't correct.
When you find some errors please let it me know. I created it with CS
Best regards
Daniel
ckuehnel
Best regards
Daniel
Thank you very much. You opened my eyes.
The pinout of the Arduino Yún has changed and I did not see this. Sorry for that.
This means that a lot of shield will be not compatible.
I will try tomorrow my I2C example with the correct pinout.
Thanks and regards
Claus
jpremor
#2
Oct 12, 2013, 07:04 pm Last Edit: Oct 12, 2013, 07:07 pm by jpremor Reason: 1
I'm arduino begginer starting on it with Yun.
Still hard for me to find the pin number in your diagram to allow the configuration on the SW.
Any thoughts?
<edit> Thanks a lot, this pic is very helpfull :) <edit>
YunJova
Good drawing.
Please add the fact the the Vin MUST be regulated 5V. This is different from the other Arduinos.
Clemens
Attention! There are many things wrong in this drawing 5 V and 3.3 V are swapped, IO Ref and Reset also--I did not check more so be careful and don't take this as truth.
sonnyyu
#5
Jan 20, 2015, 01:06 am Last Edit: Jan 20, 2015, 03:27 am by sonnyyu
Good found.
Since Yun has not break out any gpio pins of AR9331 ( in total of 29),   which made Yun as same shield as Leonardo.
jessemonroy650
Best regards
Daniel
GuggHerr,
please check the 500mA. It might be lower, may 250mA.
Attached are two (2) pictures of my Yun. The pins are labeled on the side.
Jesse
ShapeShifter
