Topic: WIRE LENGTH MEASURE AND CUTTER (Read 16342 times) previous topic - next topic
polymorph
Then you need to specify how accurate you need. Seriously, 0.5mm is too long or short at 50mm? Why?
Steve Greenfield AE7HD
Drawing Schematics: tinyurl.com/23mo9pf - tinyurl.com/o97ysyx - https://tinyurl.com/Technote8
Multitasking: forum.arduino.cc/index.php?topic=223286.0
gammon.com.au/blink - gammon.com.au/serial - gammon.com.au/interrupts
JIGNESHDHARIA
Thanks. We will consider 1% accuracy overall for any length for programming
JIGNESHDHARIA
i have logitech 99 model: m-saw83A mouse, IS it possible to use the same to measure wire length? if so what will be programme?
polymorph
JIGNESHDHARIA
Thanks, I really oblige for your  guidance for what kind of Mouse should I used for Feeding wire measurement using encoder of mouse along with programming code.
polymorph
Quote
Mechanical thing I will handle. Programming is little difficult. I require your 100% help.
I think it is time for this to move to Gigs and Collaborations.
JIGNESHDHARIA
ok! thanks, but how I shall be inform?
