Topic: Move config web (Read 3000 times) previous topic - next topic
KenNET
Is is possible to move the default site (/cgi-bin/luci/webpanel/homepage) to another port, lat say :81
Then I want my webpages on the SD card on the "root" of webserver, not like now "192.168.1.100/sd/mypage.html", I want "192.168.1.100/mypage.html"
And last how do I install PHP on Yun?  I'm not that good with linux.
Thanks!
federicofissore
#1
Sep 26, 2013, 09:08 pm Last Edit: Sep 27, 2013, 09:01 am by Federico Fissore Reason: 1
Edit file /etc/config/uhttpd, 5th row
Code: [Select]
list listen_http 0.0.0.0:80
Quote
Change
Code: [Select]
option home /www accordingly. Beware that your files will be the only one served by the webserver (ie: you'll lose access to the webpanel).
Quote
Thanks!
Access the yun via ssh or via the YunSerialTerminal. Be sure it's properly configured to access the internet then type
Code: [Select]
opkg update
opkg install php5-cgi
(or php4 if you prefer)
PS: once you're done with uhttpd configuration, don't forget to restart it:
Code: [Select]
/etc/init.d/uhttpd restart
KenNET
Wow that was fast!
Ok I got PHP working
can I run multiple webservers? Yun admin on port 81, and my with pages from SD on port 80. How do I config that?
Thanks!
federicofissore
I'm not sure that's possible. uhttpd is made for very constrained environments. Maybe google can help
KenNET
I fond this and it works. Just put # on the original settings.
Code: [Select]
# Server configuration
config uhttpd main
    option home        /www
    option cgi_prefix     /cgi-bin
config uhttpd secondary
    list listen_http    0.0.0.0:81
    option home        /mnt/sda1/arduino/www/
federicofissore
ah, well done. good to know :)
