Topic: [solved]problem with ADS1015 (Read 2730 times) previous topic - next topic
amazilia
Sep 27, 2013, 10:24 pm Last Edit: Sep 27, 2013, 11:36 pm by amazilia Reason: 1
I try to figure out how to program the Adafruit_ADS1015.
I based my tests upon this link : http://learn.adafruit.com/adafruit-4-channel-adc-breakouts/overview
I have an old UNO so neither SDA nor SCL pins. I used as mentioned  in the howto pins 4 and 5 to connect SDA and SCL respectively.
I could not repeat exactly the howto as I do not have an ADXL335. I replaced it by a 10K Breadboard trim potentiometer connecting extreme pins to 5volt and gnd and middle one to A0 on the ADS1015.
in other term I should be able to mesure voltage varying between 0 and 5 vold on pin A0
the script I used is the Single Ended Conversion script
Code: [Select]
   #include <Wire.h>
   #include <Adafruit_ADS1015.h>
   Adafruit_ADS1015 ads1015;
   void setup(void)
   Serial.println("Hello!");
   Serial.println("Getting single-ended readings from AIN0..3");
   Serial.println("ADC Range: +/- 6.144V (1 bit = 3mV)");
   ads1015.begin();
   void loop(void)
   int16_t adc0;
   adc0 = ads1015.readADC_SingleEnded(0);
   Serial.print("AIN0: "); Serial.println(adc0);
   Serial.println(" ");
the result I get is :
Code: [Select]
Hello!
AIN0: 4095
AIN0: 4095
AIN0: 4095
When I play with the knob of the pot nothing happens. I guess I do something wrong ...
Thanks for your help
Philippe
Grumpy_Mike
Quote
Those pins are the analogue pins 4 & 5 you know not the digital ones.
amazilia
Thanks for your answer.
I am following the howto. They may be wrong but I can't say, I am discovering things.
http://learn.adafruit.com/assets/2675
Philippe
amazilia
when you mesure something, mesure it three time!
I rewired things several time, and now it works. a wire was not well soldered...
Sorry for the disturbance
Philippe
