Topic: Ambient radio wave energy (Read 8963 times) previous topic - next topic
MarkT
I am trying to do a demonstration in which energy from ambient radio waves (it doesn't matter which frequency) is used to charge up capacitors and blink a red 3 volt 1 mA led every 10 seconds or so. Is this feasible? If so how can I go about building it.
The problem is that if you do find a frequency with enough power, there's no easy way to harvest it without
retransmitting harmonics (which may be illegal, potentially interferes with emergency services, aircraft, etc)
The energy retransmitted might only be 0.01% of the incident energy, but if that was enough to harvest in
the first place the retransmission will have a good range.  Radio receivers only need something like
femtowatts to pick up a signal, to power an LED needs milliwatts (12 orders of magnitude more).
You could place a small SMT 50 ohm resistor at the output of a large dipole antenna and use a pair of
temperature sensors to detect any raise in temperature of the resistor compared to nearby - thus
demonstrating the arrival of RF energy (and a simple resistor doesn't generate harmonics).
Replacing the resistor with a full-wave rectifier of germanium or shottky diodes would allow a DC voltage
to be generated, but trying to extract much current would then inject odd-harmonics back in to the antenna.
With a 50ohm load 1mW of RF is only 0.6V peak-to-peak though...
mauried
This is difficult to do.
Whilst there is a lot of radio frequency energy being transmitted from multiple radio transmitters all around
its simply not possible to somehow add it all together and generate any power.
This is because its all AC and the phase relationships of all the transmissions are not related to each other in any way.
This simplest way and the most likley is the humble MF crystal set, consisting of a simple tuned circuit to isolate a single
transmission, a diode to rectify it , and a capacitor to charge.
But dont expect to get much energy, unless you live across the road from a 50+KW transmitter.
The longer the antenna the better, and long wire antennas work well with MF broadcasting stations.
The single largest source of radio noise is the Sun, but its totally useless as its non coherant so the energy is spread
across a wide bandwidth.
cjdelphi
Do you know an energy harvesting ic that collects energy from radio waves ?
I can only find ics that use motion, or peltier, or solar, or nearby inductance, and so on.
An antenna and a diode, now depending on the size of the antenna you can absorb as much RF as possible, who's less likely to track you down for stealing microwatts of power to charge a cap?
AM probably a good source, a ferrite rod + copper coil ? you could even steal power from GSM charge it by placing it near a power supply or something...
But peltier, solar, inductance, they all create a potential voltage, so would an antenna and a radio diode, anything that produces a voltage would work.
http://www.ebay.com.au/itm/Energy-Harvester-Breakout-20-mV-Startup-/261273592646?pt=LH_DefaultDomain_0&hash=item3cd51ea346
They're getting more popular, i hope to see prices come down and then I could use a speaker and convert sound waves to energy, infact your body would generate enough heat to drive this device!
UserNotLoggedIn
RFID works on this principle.
The "tag" is bombarded with a low freq / low level energy long enough to transmit its data a few inches to a nearby receiver.
Not something that can power any microcontroller.
polymorph
Thermoelectric work by heat difference, I think in Australia your body would be the heat sink for a large part of the year! Snork.
A big problem with diodes is the voltage drop. As pointed out, 1mW into 50 ohms is only 0.6V peak, enough to turn on a germanium or shottky, but thereby wasting half the power. And a bridge rectifier doubles that drop.
Resonance boosts voltage, but at the expense of bandwidth.
Actually, there are a few projects going on where researchers are trying to use ambient RF fields to power a microcontroller, but they are -very- low power and spend most of their time storing energy, only coming on for a short time a few times a day.
Steve Greenfield AE7HD
Drawing Schematics: tinyurl.com/23mo9pf - tinyurl.com/o97ysyx - https://tinyurl.com/Technote8
Multitasking: forum.arduino.cc/index.php?topic=223286.0
gammon.com.au/blink - gammon.com.au/serial - gammon.com.au/interrupts
polymorph
BTW, I love how that chip works, the one used in that eBay link. The LTC3108. Fascinating. Uses a chopper to turn the low voltage modest current output from a thermoelectric generator into AC and sends it through a transformer to boost the voltage. I've had my eye on it for a while for a project I'm doing. I'm wondering how it would handle low frequency AC.
http://www.linear.com/product/LTC3108
polymorph
Linear also has the LTC3109 which is auto polarity:
http://www.linear.com/product/LTC3109
Not meant to take AC, but I wonder how it'd react to it.
MarkT
I dispute that - RFID readers run quite high power typically, and tags are a small microcontroller in the general case.  I've played with one RFID reader chip and it handles
upto 200mA of coil drive current at upto 8V.
Grumpy_Mike
If you strip an RFID tag down and connect an LED across the coil it will light up when presented to the reader. We used to have an RFID tag in a transparent case that our CEO used to have to impress his clients, I have made several.
MarkT
For pete's sake don't let the "(microwave oven owning) keep WiFi out of our schools" crowd
hear that!
polymorph
I demonstrated some of the effects of resonance by having an untuned coil connected to a signal generator, an untuned coil connected to a couple of antiparallel LEDs, then I insert an LC tuned circuit.
