Topic: Problem with Serial.read and bigger numbers (Read 3245 times) previous topic - next topic
Raavgo
Hey guys,
I've got a problem with my code...
The code should read a frequency and generate a square-wave signal but I can't read numbers bigger than 9.
Code: [Select]
int Ausgangspin = 13;
double Frequenz;
void setup(){
  pinMode(Ausgangspin, OUTPUT);
  Serial.println("Bitte angeben wieviel Hz ausgegeben werden sollen:");
void loop(){
  Frequenz = Eingabe();                                                  //Eingabe-Funktion, gibt die Frequenz zurück.
  Serial.print("Es wird gesetzt: ");
  Serial.print(Frequenz,DEC);
  Serial.println("Hz!");
  //tone(Ausgangspin, Frequenz);                                  // Ausgabe der frequenz ohne abhängigkeit der Zeit
int Eingabe(){
int  i = 0;                                                            //Ziffern-Zähler rücksetzen
unsigned char Data[6];                                          // String zum einlesen der Zahlen
  do
    if (Serial.available())                                              // Wenn Daten verfügbar 5 Zeichen in Data schreiben
      Data[i] = Serial.read() - '0';                                  //umwandlung zu DEC
      i++;
  while (i<5);
  return atof(Data);                                                    //return Zeichenkette -> Zahl (DEC)
but I already tried something else (Well it didn't work either)
Code: [Select]
int  i = 0, f = 0; //Ziffern-Zähler rücksetzen
if (Serial.available()>0)
    for (i=0 ; Serial.available() >0&& i<5 ; i++)
    Data[i] = Serial.read();
    Serial.flush();
    Serial.println(atof(Data));
If I want to get a numeric output of the number 50 I get it as 5.00 and 0.00
thanks for any kind of help
Raavgo
AWOL
Code: [Select]
When you get to the start of this for loop, you will probably have just one character available to read.
After one iteration of the for loop, you will probably have no more characters available to read.
How many times will the loop iterate?
PaulS
A clue as to what is sending the data would be useful.
robtillaart
considered this variation?
Code: [Select]
if (Serial.available() >= 5)  // <<<<<<<<
    for (i = 0 ; i < 5; i++)
    Serial.flush();
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
PaulS
Quote
I'd be more likely to consider that if the useless Serial.flush() was removed.
Raavgo
My Problem is I want to read numbers from the Serial Monitor.
The range should be from 1 to 99999 but I'm messing up somehow.,
I'm able to only read 5 digit numbers so if I want to write 10 I'd have to write 00010.
thank you
Raavgo
PaulS
Quote
That wouldn't be the case if you used end of packet markers. The Serial Monitor can even add them for you.
AWOL
Quote
There are a couple of things to bear in mind here:
1) An Arduino "int" holds at most only five decimal digits. To hold more, you need a "long" or unsigned long". Or even a "long long"
2) Some methods of converting ASCII to "int" will consider "00010" to have the decimal value 8 - a leading '0' denotes an octal value.
robtillaart
Quote
an int can also hold a - sign  ==> in theory in 50% of the cases (in practice probably less)
an unsigned int will hold 5
Rob Tillaart
AWOL
Signed or unsigned, a sixteen bit "int" will only ever hold five decimal digits.
Raavgo
Quote
Could you give me a example how to read the number 50000 out of a serial Monitor and store it in a int or unsigned int?
AWOL
There are plenty of examples out there, but one hint would be to set the line-ending in the serial monitor to "Newline", instead of the default "No line ending"
PaulS
This code uses start and end of packet markers:
Code: [Select]
#define SOP '<'
#define EOP '>'
bool started = false;
bool ended = false;
char inData[80];
byte index;
  Serial.begin(57600);
  // Other stuff...
 // Read all serial data available, as fast as possible
 while(Serial.available() > 0)
   char inChar = Serial.read();
   if(inChar == SOP)
      index = 0;
      inData[index] = '\0';
      started = true;
      ended = false;
   else if(inChar == EOP)
      ended = true;
     if(index < 79)
       inData[index] = inChar;
       index++;
 // We are here either because all pending serial
 // data has been read OR because an end of
 // packet marker arrived. Which is it?
 if(started && ended)
   // The end of packet marker arrived. Process the packet
   // Reset for the next packet
   started = false;
   ended = false;
   index = 0;
Where it says "Process the packet"., you do whatever you need to do with the serial data, stored in inData. You could remove SOP and the started flag (and related code) if you only want to use an end-of-packet marker.
odometer
#13
Oct 07, 2013, 04:51 pm Last Edit: Oct 07, 2013, 04:53 pm by odometer Reason: 1
No need to muck about with character arrays or strings, or packet monitors for that matter.
You can simply multiply what you already have by 10 and then add the new digit.
But you have to start from 0.
So if I type the number 753:
It sees 7 and figures (0*10)+7 to get 7.
Then it sees 5 and figures (7*10)+5 to get 75.
Then is sees 3 and figures (75*10)+3 to get 753.
Here is my version of Eingabe(). Note its simplicity.
Please test it and tell me if it works correctly for you.
Code: [Select]
unsigned long Eingabe(){
 unsigned long value = 0;
 char char_in = -1;
 while (Serial.available())   // just keep reading characters
   char_in = Serial.read();
   if (char_in != -1) {       // check to make sure there is a character
     if ((char_in >= '0') && (char_in <= '9')) {  // is it a digit?
       value *= 10;                               // multiply total by 10
       value += (char_in - '0');                  // add numeric value of new character
     else return value;   // if the new character is not a digit, then we are done
 return 0; // in case Serial doesn't seem to be working
(Oops! I just corrected a typo.)
AWOL
Odometer: There's a problem with your code - it assumes all the data it needs to read from the serial line is already there.
