Topic: ~(solved)Wave Pattern~ (Only Single Sided Snake Trail!!!!!) (Read 4255 times) previous topic - next topic
Nishant_Sood
Oct 01, 2013, 09:25 pm Last Edit: Oct 05, 2013, 09:19 pm by NI$HANT Reason: 1
I have this>> http://www.youtube.com/watch?v=oVGDMrQmWKc  wave working in the single side but I want the same wave to flow the other way too! which until now I'm not able to accomplish actually it should be a matter of just decrementing the values of RED led brightness systematically  and incrementing the brightness systematically in this line >>  Addup = Addup - 655360;  to achieve the desired effect but it isn't working right now, May be I'm wrong which is not a big deal it happens in programming.
The Strip that I'm working is a WS2801 chip and it's available here >> https://www.sparkfun.com/products/11272
Here's the code>> http://pastebin.com/5Xu4VWKC
"Real Men can Accomplish  Anything"
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
PaulS
I don't do rubbish bin. Post the code as an attachment.
hib1
I would try this if  "STRIP_LENGTH" is the number of LEDs in your strip.
Code: [Select]
//Runs a wave of LED's backwards
void post_frame_moreLEDS_back (long LEDcolor, int startLED, int endLED) {
  for(int LED_number = STRIP_LENGTH ; LED_number =0; LED_number--)
Nishant_Sood
@PaulS
Please have the code as an Attachment (I originally wanted to post code within the post but it said its too much!)
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
Nishant_Sood
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
PaulS
Code: [Select]
unsigned long prevValue , currValue, Addup = 16711680, this_led_color;
Magic numbers need explanations.
Code: [Select]
  for(int x = 0 ; x < STRIP_LENGTH ; x++)
    strip_colors[x] = 0;
Global variables are initialized for you.
Code: [Select]
  if (endTime - startTime < 30 && checkBUTTON == false){
    rightWIDTH = 29;
    Serial.println("30 leds");
  else if (endTime - startTime >= 30 && endTime - startTime <= 40 ) {
    rightWIDTH = 34;
    Serial.println("35 leds");
  else if (endTime - startTime >= 40 && endTime - startTime <= 50 ) {
    rightWIDTH = 39;
    Serial.println("40 leds");
  else if (endTime - startTime >= 50 && endTime - startTime <= 60 ) {
    rightWIDTH = 44;
    Serial.println("50 leds");
  else if (endTime - startTime >= 60 && endTime - startTime <= 70 ) {
    rightWIDTH = 49;
    Serial.println("60 leds");
  else if (endTime - startTime >= 70 && endTime - startTime <= 80 ) {
    rightWIDTH = 54;
    Serial.println("70 leds");
  else if (endTime - startTime >= 80 && endTime - startTime <= 90 ) {
    rightWIDTH = 59;
    Serial.println("80 leds");
  else if (endTime - startTime >= 90 && endTime - startTime <= 100 ) {
    rightWIDTH = 64;
  else if (endTime - startTime >= 100 && endTime - startTime <= 110 ) {
    rightWIDTH = 69;
  else if (endTime - startTime >= 110 && endTime - startTime <= 120 ) {
    rightWIDTH = 74;
    Serial.println("75 leds");
  else if (endTime - startTime >= 120 && endTime - startTime <= 130 ) {
    rightWIDTH = 80;
  else if (endTime - startTime >= 130 && endTime - startTime <= 140 ) {
    rightWIDTH = 84;
  else if (endTime - startTime >= 140 && endTime - startTime <= 150 ) {
    rightWIDTH = 89;
  else if (endTime - startTime >= 150 && endTime - startTime <= 160 ) {
    rightWIDTH = 94;
  else if (endTime - startTime >= 160 && endTime - startTime <= 170 ) {
    rightWIDTH = 99;
  else if (endTime - startTime >= 170 && endTime - startTime <= 180 ) {
    rightWIDTH = 104;
  else if (endTime - startTime >= 180 && endTime - startTime <= 190 ) {
    rightWIDTH = 109;
  else if(endTime - startTime > 190){
There would be a hell of a lot less typing, and calculating, if you calculated endTime - startTime ONCE.
Code: [Select]
    post_frame_moreLEDS_testing(0x000000, a, a+size2);
How does that differ from 0 or 0x0 or 0b0?
Code: [Select]
void post_frame_moreLEDS_testing (long LEDcolor, int startLED, int endLED) {
Out the curly brace on the line with the statement, to save a line. Then, add a blank line. Makes sense to me. NOT!
Code: [Select]
      this_led_color = 0x000000; //24 bits of color data
No, it isn't.. 0x000000 is still 0. That's a 16 bit 0.
Code: [Select]
    for(byte color_bit = 23 ; color_bit != 255 ; color_bit--) {
        Addup = Addup + 655360;
More magic number with no explanation.
Having read through your code, I still can't understand what your problem is.
Quote
That's pretty lame, you know. The code does something. Only you can see what it does.
Nishant_Sood
#6
Oct 04, 2013, 07:39 am Last Edit: Oct 04, 2013, 07:50 am by NI$HANT Reason: 1
Quote
You just need to be considered with variables Addup(this 16711680 depicts 0xFF0000 in decimal form) and this_led_color is the variable that stores color that is to be loaded to the latest LED in the for loop.
Sorry for ignorance these must have been defined by me.
Quote
I just typed one IF condition and then copied and pasted the other statements so that doesn't make any difference, although you are right.
Quote
Well you can see it too ,on the very first post I posted a YouTube video which shows the animation the function >>post_frame_moreLEDS_testing() is making YOU JUST NEED TO CONSIDER THIS FUNCTION AS THIS IS THE PLACE WHERE IT NEEDS CHANGES TO RUN THE ANIMATION THE OTHER SIDE.
Basically if you will see the video then you'll see that the snake trail animation is running from left to right only! I'm trying to also have it run from right to left!
In the video you can see the flow is going from left to right!
How it's happening is by adding to or deducting to the variable Addup, If the variable Addup is initially declared with 16711680 value(that is 0xFF0000 red full on) then deducting it by 65536 deducts 1 bit in the 0 to 255 byte range so basically i'm controlling the brightness(decreasing it) like this as such when the statement (Addup = Addup - 655360;    )runs embedded under the for loop it deducts 10 x 65536 values for fast effect on the wave.
But the problem is that the wave flow effect I think must run from other side if I make the Addup variable = 0 and then add values in the forloop(in the statement Addup = Addup + 655360;) thus increasing the brightness but it shows the same effect?!!
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
PaulS
Quote
Oh, well, that's obvious. Why not simply use 0xFF0000 in the code?
Quote
Your statement may be true regarding the amount of typing. It is not true that it makes no difference. Calculating the difference 20 times takes longer than calculating it once. Though the compiler may be smarter than you, and generate the proper machine code to do the calculation only once.
Nishant_Sood
Quote
just for the clarity of the thought process.
yes you are true that the Compiler mabe smart its my duty to do the time Calculation once.
Any insights on the Animation working?
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
int2str
*sigh*
I think somebody should develop a keyboard for programmers, that automatically lights your fingers on fire if you copy the same section of code more than once.
1. Use functions
2. Use arrays, loops and most importantly: math instead of cascades of "if" statements
If you make your code clear, concise and driven by a loop, reversing the order will be no problem.
Nishant_Sood
Quote
Okay that's fine
But you won't havr said this if it was for a switch case statement you see this is what they are made for although what you say is correct and implicable but aattimes when you have to implement fast functions that work flawlessly you don't have the time to think about the for loops off course these cascades of if conditions can be later on converted into switch or for loop things but the time called for focusing on some other part of the system also these if conditions play no role in creation of the needed Animation
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
PeterH
I'm sorry to contradict you, but that is completely wrong in every respect. The way to develop flawless code fast is to use the most appropriate control constructs in the first place, don't introduce duplicate code in the first place and don't use error-prone bug-encouraging approaches like copy/paste. If you "don't have time" to do it right because you are "focusing on some other part of the system" then you certainly don't have time to waste on a slower, more error-prone approach. Doing it right produces shorter, simpler code which takes less time to write and test and fix.
Nishant_Sood
I have solved the problem! With the same set of code
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
int2str
This is not success.
Now that you've hacked the Sparkfun example code to high hell to get it to do what you want, I would take that opportunity to rewrite the code and implement a new algorithm that does the same thing in an understandable and readable way.
If you're at all interested in improving your coding, this would be a great project to tackle.
Btw. while I'm fairly sure the Sparkfun example code is public domain, I think you should still give them some credit if you're essentially using it as-is and then just adding your bits. Also, the Sparkfun example code isn't all that great to be honest, so if you decide to re-write it, I'd start from scratch if I was you.
Nishant_Sood
#14
Oct 05, 2013, 09:37 pm Last Edit: Oct 05, 2013, 09:52 pm by NI$HANT Reason: 1
Quote
Yes it is, You don't even care about what my real problem was the things you are talking are correct but come along with what I want and not push the ultimate question back as you did.
I will make the code formulated
Quote
Quote
Now are you fumed I think you are because Whatever I was able to make it work, What's your problem just keep it at your part.
Talk responsibly don't  use aggressive words like hell or whatever you think its fine for you.
Quote
Have you seen the code that is with me and it's working? that you are assuming that I'm giving them credit or not? I'll tell, You haven't seen it you are just talking in the air.
Everybodies using libraries we use tonne's of them already while using c/c++/c#/java and I'm not even using any here in my program.
People like you are there to put other's down that's it but remember you don't get up and achieve anything by putting down other's may be its personal gratification for you.
(I'm sorry for you ,your words are all spitting fire and they no longer seem to be there clear things but are there to insert disgust feeling.)
Quote
@PeterH thank you I will take care or that.
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
