Topic: How to write in Serial Monitor what I enter? (Read 6332 times) previous topic - next topic
Daniel_DSO
Hi, how are you?
Well, I need enter with numbers in Serial Monitor and do some calculations with that number. So, when I enter, I take to print it, but when it's printed, the character come in ASCII and separated, for example:
1 - I enter with numbers: 345
2 - Print thus:   50
                       51
                       52
Then, I'd like to print what I entered, like:
1 - I enter with number: 345
2 - Print thus: 345
Someone knows how to do it?
Thanks so much.
zoomkat
The problem is with your code, which you have failed to post (use the code tag # in the tool bar when posting). Perhaps you are using Serial.write instead of Serial.print. Below is some simple serial test code.
Code: [Select]
// zoomkat 7-30-11 serial I/O string test
// type a string in serial monitor. then send or enter
// for IDE 0019 and later
String readString;
  Serial.println("serial test 0021"); // so I can keep track of what is loaded
  while (Serial.available()) {
    delay(2);  //delay to allow byte to arrive in input buffer
    char c = Serial.read();
    readString += c;
  if (readString.length() >0) {
    Serial.println(readString);
    readString="";
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
jroorda
When you talk to the board with the serial monitor it sends characters, you need to parse these characters back into a number on the Arduino.  The standard C atoi() function does this nicely.  I think that needs an stdlib.h header file, but don't take my word for that.  If you give that function a c-string (char array) of numerals it will spit out an integer.  There are other flavors if you want something other than an int.
For small values (0-255) that would fit in a byte variable you can also send characters who's ASCII value is equal to the number you want.  This takes some work with the Arduino serial monitor, but it is an option for some other terminals like Realterm.  http://realterm.sourceforge.net/
Daniel_DSO
Ok, It's works zoomkat. But it keep printing separated.
For example, I enter with number 259, but print one under the other, like: 2
        5
        9
I like to print in the same line, like 259.
What should I do?
Thanks.
PaulS
Quote
What should I do?
Use some code that understands end-of-packet markers, and use them!
The serial monitor can send nothing, CR, or CR/LF, as the end of packet marker, depending on what you set using the drop-down menu in the lower, right corner. Then, you could modify this code:
Code: [Select]
#define SOP '<'
#define EOP '>'
bool started = false;
bool ended = false;
char inData[80];
byte index;
  Serial.begin(57600);
  // Other stuff...
 // Read all serial data available, as fast as possible
 while(Serial.available() > 0)
   char inChar = Serial.read();
   if(inChar == SOP)
      index = 0;
      inData[index] = '\0';
      started = true;
      ended = false;
   else if(inChar == EOP)
      ended = true;
     if(index < 79)
       inData[index] = inChar;
       index++;
 // We are here either because all pending serial
 // data has been read OR because an end of
 // packet marker arrived. Which is it?
 if(started && ended)
   // The end of packet marker arrived. Process the packet
   // Reset for the next packet
   started = false;
   ended = false;
   index = 0;
Remove the started variable, and all the places it is used. Change the EOP value to \n or \r, depending on what you set in the serial monitor. Where it says "Process the packet", your "processing" consists of printing it.
zoomkat
        5
        9
What should I do?
Thanks.
Did you type in 259 and hit enter, or did you type 2, hit enter, type 5, hit enter, type 9, hit enter? You can add an end of packet delimiter (the default serial monitor settings do not add one) like a comma in the below code. The delimiter indicates the end of the character string being sent and starts processing of the code.
Code: [Select]
//zoomkat 3-5-12 simple delimited ',' string parse
//from serial port input (via serial monitor)
//and print result out serial port
String readString;
  Serial.println("serial delimit test 1.0"); // so I can keep track of what is loaded
  //expect a string like wer,qwe rty,123 456,hyre kjhg,
  //or like hello world,who are you?,bye!,
  if (Serial.available())  {
    char c = Serial.read();  //gets one byte from serial buffer
    if (c == ',') {
      //do stuff
      Serial.println(readString); //prints string to serial port out
      readString=""; //clears variable for new input
    else {
      readString += c; //makes the string readString
