Topic: Arduino generating prime numbers (Read 43182 times) previous topic - next topic
nickgammon
Absolutely they are chainable. I had a test set up yesterday. Code here:
http://www.gammon.com.au/forum/?id=11516&reply=3#reply3
I'm not sure about the speed of doing long longs. I could find out, I suppose. :)
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
nickgammon
The code below generates a 16-digit prime number using two daisy-chained displays, using long long arithmetic.
Code: [Select]
// Prime number generator using long long
// Author: Nick Gammon
// Date:   22nd October 2013
#include <SPI.h>
#include <EEPROM.h>
#include <EEPROMAnything.h>
#include <limits.h>
const int CHIP_COUNT = 2;  // how many MAX7219s
const int SHOW_EVERY = 100;  // how often to echo a prime to the serial port (and update EEPROM)
const unsigned long TIME_TO_WAIT = 500;  // mS
const long long FIRST_PRIME_TO_USE = 99999999999LL;  // if ULONG_MAX then read from EEPROM
// MAX7219 registers
const byte MAX7219_REG_NOOP        = 0x0;
// codes 1 to 8 are digit positions 1 to 8
const byte MAX7219_REG_DECODEMODE  = 0x9;
const byte MAX7219_REG_INTENSITY   = 0xA;
const byte MAX7219_REG_SCANLIMIT   = 0xB;
const byte MAX7219_REG_SHUTDOWN    = 0xC;
const byte MAX7219_REG_DISPLAYTEST = 0xF;
// 7-segments patterns for digits 0 to 9
const byte digits [10] = {
  0b1111110,  // 0
  0b0110000,  // 1
  0b1101101,  // 2
  0b1111001,  // 3
  0b0110011,  // 4
  0b1011011,  // 5
  0b1011111,  // 6
  0b1110000,  // 7
  0b1111111,  // 8
  0b1111011,  // 9
void sendToAll (const byte reg, const byte data)
  digitalWrite (SS, LOW);
  for (int chip = 0; chip < CHIP_COUNT; chip++)
    SPI.transfer (reg);
    SPI.transfer (data);
  digitalWrite (SS, HIGH);
  }  // end of sendToAll
void sendChar (const int which, const char c)
  byte i;
  // segment is in range 1 to 8
  const byte segment = 8 - (which % 8);
  // for each daisy-chained display we need an extra NOP
  const byte nopCount = which / 8;
  // start sending
  // send extra NOPs to push the data out to extra displays
  for (byte i = 0; i < nopCount; i++)
    SPI.transfer (MAX7219_REG_NOOP);
    SPI.transfer (MAX7219_REG_NOOP);  // need 16 bits of NOP
  // send the segment number and data
  SPI.transfer (segment);
  SPI.transfer (c);
  // start with enough NOPs so later chips don't update
  for (int i = 0; i < CHIP_COUNT - nopCount - 1; i++)
  // all done!
  }  // end of sendChar
// write an entire null-terminated string to the LEDs
void sendString (const char * s)
  for (int pos = 0; *s; pos++)
    sendChar (pos, *s++);
}  // end of sendString
long long candidate;
long found = 5; // Number we found
int count = found - 1;
  while (!Serial) { }
  Serial.println ();
  Serial.println ();
  SPI.begin ();
  sendToAll (MAX7219_REG_SCANLIMIT, 7);      // show 8 digits
  sendToAll (MAX7219_REG_DECODEMODE, 0xFF);  // use digits (not bit patterns)
  sendToAll (MAX7219_REG_DISPLAYTEST, 0);    // no display test
  sendToAll (MAX7219_REG_INTENSITY, 15);      // character intensity: range: 0 to 15
  sendToAll (MAX7219_REG_SHUTDOWN, 1);       // not in shutdown mode (ie. start it up)
  candidate = FIRST_PRIME_TO_USE;
  if (candidate == ULONG_MAX)
    EEPROM_readAnything (0, candidate);
    EEPROM_writeAnything (0, candidate);
unsigned long start;
unsigned long lastShown;
  for ( ; candidate < 9999999999999999LL; candidate += 2)
    showIfPrime (candidate);
  candidate = 3;  // back to start!
  }  // end of loop
void showIfPrime (long long num)
  // we are already skipping odd numbers, now skip if divisible by 3
  if (num % 3 == 0)
    return;
  // Only have to check for divisible for the sqrt(number)
  long long upper = sqrt(num) + 6;
  // Check if the number is divisible (start at 6 going up)
  for (long long cnum = 6; cnum <= upper; cnum += 6)
    if (num % (cnum - 1) == 0)
      return;
    if (num % (cnum + 1) == 0)
      return;
    }  // end of checking cnum-1, cnum+1
  char buf [20] = { 0 };
  long long temp = candidate;
  byte pos = 0;
  // make printable
  for (pos = 0; pos < 16; pos++)
    if (temp == 0)
    char digit = temp % 10;
    buf [15 - pos] = digit | '0';
    temp /= 10;
// insert leading spaces
  for (; pos < 16; pos++)
    buf [15 - pos] = 15;
// echo to serial port for validating
if (++count >= SHOW_EVERY)
  Serial.print(buf);
  Serial.print(" is prime. Took ");
  Serial.print(millis () - start);
  Serial.print (" mS. Found ");
  Serial.print (found);
  Serial.println (" primes.");
  start = millis ();
  count = 0;
  for (byte i = 0; i < 5; i++)
    sendString ("\x0F\n\x0F\n\x0F\n\x0F\n\x0F\n\x0F\n\x0F\n\x0F\n\x0F");  // warn not to turn off
    delay (500);
    sendString ("\x0F\x0F\x0F\x0F\x0F\x0F\x0F\x0F\x0F\x0F\x0F\x0F\x0F\x0F\x0F\x0F");  // blink
    delay (500);
    }  // end of for
  EEPROM_writeAnything (0, candidate);  // for restarting next time
  }  // end of if time to write to serial and update EEPROM
  found++;
  // delay until interval is up
  // (this absorbs the calculation time)
  while (millis () - lastShown < SHOW_EVERY)
  sendString (buf);
  lastShown = millis ();
}  // end of showIfPrime
This has slowed it down somewhat, as you might expect. The time between calculating 100000000063 and 100000000069 was 28 seconds.
JChristensen
I'm up to 8 digits!
Nick, is the 8-digit version still running?  Wondering if it's rolled over yet.  I finally breadboarded one up here.  I took the delay out, it's been running 10 or 12 hours, it's up to 13,000,000 and change.  It will also save the time to EEPROM when it rolls over.  The longer it runs, the slower it goes...
nickgammon
The 8-digit one is up to 444xxxxx. I'm saving the current number to EEPROM every 500 numbers (around every 4 minutes). That's just in case the power goes. It still seems to be keeping up with the rate of two every second.
odometer
How is the compiler with division? From what I heard, it leaves something to be desired.
You might want to optimize. See:
http://www.steike.com/code/bits/division/
What I am suggesting is this:
You don't need to do modulus the normal way. Instead, since you only want to test for divisibility, you can try a trick: assume that the division is exact, try to divide from right to left, and see whether you get a valid answer or just garbage. For this, it would help to have a table of multiplicative inverses modulo 256.
nickgammon
If you want to modify my code further up you are welcome to demonstrate this.
I should point out that this is using long long type (64 bits) which probably makes the processor work fairly hard. I don't have memory for a lot of inverses, and indeed the problem with a prime number like 100000000063 is that you don't get any quick matches, so it has to do a lot of divisions (obviously excluding even numbers) to make sure it is prime.
Code: [Select]
?100000000063 / 4 = 79057
So I suppose it is OK that it takes 23 seconds to do 79057 long long divisions. But I am certainly open to faster methods, bearing in mind such methods only have 2 kB of RAM to work in.
odometer
First of all, I hope your square root is working properly.
If you are going to convert to a float before taking the square root, you lose precision, and possibly your square root will come out too low-- you know what that means.
In which case, you might want to get at your limit using something like:
Code: [Select]
limit = (long long)sqrt((float)n)
limit = max(limit, n/limit)
What I meant by avoiding division was this:
Begin by assuming that the division does come out even, and go ahead and divide.
For example, let's say you are testing 21005 for divisibility by 5. You and I can at once see it divides, but remember, the Arduino is testing 0x520D for divisibility by 0x05.
We go ahead and divide.
Hex number ends in: 0 1 2 3 4 5 6 7 8 9 A B C D E F
Quintuple ends in: 0 5 A F 4 9 E 3 8 D 2 7 C 1 6 B
Which we can rearrange as:
Quintuple ends in: 0 1 2 3 4 5 6 7 8 9 A B C D E F
Hex number ends in: 0 D A 7 4 1 E B 8 5 2 F C 9 6 3
Note that this, as well, is an arithmetic progression modulo sixteen.
Multiply the "quintuple" by 0xD to get the "original" number.
So we don't need the whole table, just the entry for 1.
0x520D ends in D. 0xD times 0xD gives us 0xA9. So our quotient ends in 9.
0x520D - (0x9 * 0x5) = 0x51E0, and we slough off the final 0.
0x51E ends in E. 0xE times 0xD gives us 0xB6. So our next quotient digit is 6.
0x51E - (0x6 * 0x5) = 0x500, and we slough off the final 0.
0x50 ends in 0. 0x0 times 0xD gives us 0x0. So our next quotient digit is 0.
0x50 - (0x0 * 0x5) = 0x50, and we slough off the final 0.
0x5 ends in 5. 0x5 times 0xD gives us 0x41. So our next quotient digit is 1.
0x5 - (0x1 * 0x5) = 0x0, so we're done.
The quotient is 0x1069.
Check by multiplication: 0x1069 * 0x5 = 0x520D
Because our dividend has only four digits, we know we must terminate within four digits. If the algorithm had not terminated soon enough, we would know that we were getting a garbage result, and that the division did not come out even after all.
robtillaart
Quote
you can check the 30K + i method as I referred to in #2  it should be a bit faster as it only tests 8 numbers of every 30 (is approx 1 in 4) where the 6k+i test 2 numbers in 6  (1 in 3) ~~> gain 10%?
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
nickgammon
Sure, but the version using longs does one every 1/2 seconds which I am fine with, and for the long long version saving 10% over 27 seconds isn't that impressive.
I was hoping for one of those "probability" primality tests to work, but my brain isn't quite up to the maths right now.
robtillaart
A substantial gain could be made if you could get from long long (64)  to long (32)
Not tested, but just an idea
first one tests 6k-1   if (n % (k-1) == 0) return
then one test  6k+1  if (n % (k+1) ==0) retrun
One might do the following first:
let p = n /(k+1);
then  n%(k+1) <==>  n - p*(k+1);
This takes an equal amount of time, but with p we have an estimation for  q = n/(k-1):  q >= p
With this estimation we can simplify the #digits
then  n%(k-1)  <==>  (n-p*(k-1)) % (k-1)
the multiplication p*(k-1) is relative fast and  if  (n- p*(k-1)) would fit in a long  the remaining % would be 32 bit iso 64 bit.
Note a long % is 6 times faster than a long long  %
Rob Tillaart
odometer
Do you even need to use the divide or modulo operators?
If the / and % operators were forbidden to you, how then would you go about this?
robtillaart
a well known method without division is the sieve
1) make a bool  array on 2..n, set them all to true
2)  take next element from array (first elm == 2) and print it
3) remove all multiples of this element from the array
4) goto step 2
array = 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 ...
take next element (2)
array = 3 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 35 ...
take next element (3)
array = 5 7 11 13 15 17 19 23 25 29 31 35 ...
take next element (5)
array = 7 11 13 15 17 19 23 29 31 ...... Note this partial list are all prime
the sieve is very slow in the begin and uses a lot of memory ( at least 1 bit per number). So an UNO with 2000 bytes RAM can hold max  16000 numbers
(we can skip the even ones) so 0.. 32000
Rob Tillaart
odometer
I didn't mean "don't divide" or "don't calculate remainders".
What I meant was, don't use the divide or modulo operators provided as part of the programming language.
Again, see: http://www.steike.com/code/bits/division/
Also see: http://gmplib.org/manual/Exact-Division.html
robtillaart
#28
Oct 29, 2013, 07:32 pm Last Edit: Oct 29, 2013, 08:29 pm by robtillaart Reason: 1
Quote
This trick is well known,
If I understand it correctly one needs to know the inverse of the divider in advance. As the prime generator goes into the millions the compiler cannot generate all this numbers in advance. The program would not fit the memory. Calculating them runtime is almost as expensive as the division in itself (I assume).
Quote
assume one test:  x % n == 0;
One could implement a quick check to see if it is a possible divider, just by checking if the last byte of x is a possible multiple of n. For this one a lookup table with the possible last bytes of multiples of n.  128 tables needed (odd numbers only) of 256 bits (=32bytes)  ==> 2^7 * 2^5 = 4096 bytes. Too much for UNO, but doable for a MEGA,
pseudo-code
p = lastbyte of X;
if (array[n/2][p] == false) ==> division not possible
fascinating...
update: a test showed that all outcomes occur when looking at the last n bits (iso last digit in decimal system). This is due to the fact that odd numbers (which are checked as dividers) are relative prime to powers of 2 (basic number theory - long ago) which is the anount of possible values for the last n bits.
see simple example for 2 bits below
Code: [Select]
01 * 00 = 00
01 * 01 = 01
01 *  10 = 10
01 * 11 = 11
11 * 00 = 00
11 * 01 = 11
11 * 10 = 10
11 * 11 = 01
All outcomes are in the last column, so it cannot be used as a selection.
In short this trick does not work for binary or hex representations, (Or convince me that I'm wrong ;)
Rob Tillaart
nickgammon
I trust you are jesting here. I have 2 kB of RAM, and I am trying to calculate a 16 decimal digit prime number. Even representing each number as a bit, they are not going to fit.
