Topic: Arduino generating prime numbers (Read 43214 times) previous topic - next topic
nickgammon
No I didn't, the library basically uses the standard number.c file which I found somewhere.
I thought you said you modified that library for Arduino.
I took the standard number.c file and added a class wrapper around it so you didn't have to muck around with malloc and free all over the place. So the low-level computations are the same.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
nickgammon
Code: [Select]
#include "Pseudoprimes.h";
Where is this file?
tmd3
"Pseudoprimes.h" ... Where is this file?
The text at reply #87, where the latest version of the sketch is attached, says that the included file - Pseudoprimes.h - still slumbers at reply #70.  But it didn't mean to say that; it meant to say it was attached to some other reply, since it's not at #70, and it was at reply #69 last time I saw it.
Fixed #87; attached a copy of sketch and included file here.
nickgammon
NiceAntoine
Estimated Nick Gammon,
I LOVE prime numbers. In order to make the arduino works faster, I would like to program a prime number generating routine (just for fun purpose) using someting that make the arduino run faster.
Is there a way to do it in C? I mean a simple way, to program the arduino in C language to make it run faster calculus programs?
After many days of research, I did not found a tutorial clear enough. I even turning myself to PIC ,as there is lots of tutorial to program those on C with a 9$ programmer.
However, I think that with a FTDI breakout, a direct C programming should be easy.
Thank for helping me.
PS: I just love this project qnd the porting for big numbers!!!
MarkT
encrypted_toast
How would you be able to generate prime numbers with the push of a button using an impulse counter?
SimonAllen
Ok.  So I am late to the party  I have cobbled this together but have all 8 LEDs fully lit including the decimal points.  It could be that I have a wrong connection
I have connected
VCC to 5V
GRD to GRD
DIN to pin 12
CS to pin 10 and
CLK to pin 13
If that is all good can anyone suggest where I have strayed?
SimonAllen
#98
Sep 10, 2017, 12:13 am Last Edit: Sep 10, 2017, 10:07 pm by SimonAllen
Ok.
I think I have figured it out
I had
VCC to 5V
GRD to GRD
DIN to pin 12
CS to pin 10 and
CLK to pin 13
I have changed it to
VCC to 5V
GRD to GRD
DIN to pin 11
CS to pin 10 and
CLK to pin 13
and now it is counting primes.
