Topic: Arduino Yun - First (very complicated and frustrating) experience (Read 9805 times) previous topic - next topic
sonnyyu
also, since the board is running an operating system, can it establish two instances of WiFi connection, one as the client and the other as the server?
No, only possible with multiple wireless network adapters, or in theory with multi-radio adapters. Yun has build in one,  add one more usb wifi adapter.
sonnyyu
can you, though, force both? can you make the Yun act as an Access Point while connected to your home router, for example, through the ethernet?
Code: [Select]
nano /etc/config/network
remove wan section:
Code: [Select]
config interface 'loopback'
config interface 'lan'
        option ifname 'eth1'
        option type 'bridge'
        option proto 'static'
        option ipaddr '192.168.0.239'
        option netmask '255.255.255.0'
        option gateway '192.168.0.1'
        option dns '192.168.0.1'
Code: [Select]
reboot
Code: [Select]
route
Code: [Select]
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
default         192.168.0.1     0.0.0.0         UG    0      0        0 br-lan
192.168.0.0     *               255.255.255.0   U     0      0        0 br-lan
Code: [Select]
/etc/init.d/dnsmasq disable
/etc/init.d/dnsmasq stop
http://wiki.openwrt.org/doc/recipes/bridgedap
nightknight
thank you so much for your replies. it will take me some time to absorb what you recommended since i am still pretty new. but i guess the simple answer is "no. but maybe with some serious tweak."
