Topic: RC Car controlled Wirelesly (Read 13394 times) previous topic - next topic
AllSystemGO
Sure thing. Here's my Arduino code
Code: [Select]
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_PWMServoDriver.h"
#include <Bridge.h>
#include <Console.h>
#include <Wire.h>
#include <YunServer.h>
#include <YunClient.h>
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
// Select which 'port' M1, M2, M3 or M4. In this case, M1
Adafruit_DCMotor *frontWheels = AFMS.getMotor(2);
// You can also make another motor on port M2
Adafruit_DCMotor *rearWheels = AFMS.getMotor(1);
const int ledPin = 13; // the pin that the LED is attached to
int incomingByte;      // a variable to read incoming serial data into
// We open the socket 5678 to communicate.
YunServer server(5678);
  // Bridge startup
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, LOW);
  Bridge.begin();
  digitalWrite(ledPin, HIGH);
  AFMS.begin();  // create with the default frequency 1.6KHz
  // Set the speed to start, from 0 (off) to 255 (max speed)
  frontWheels->setSpeed(0);
  frontWheels->run(FORWARD);
  // turn on motor
  frontWheels->run(RELEASE);
  //OTHER MOTOR
  rearWheels->setSpeed(0);
  rearWheels->run(FORWARD);
  // turn on motor
  rearWheels->run(RELEASE);
  server.noListenOnLocalhost();
  server.begin();
  uint8_t i;
  YunClient client = server.accept();
  // There is a new client?
  if (client) {
    String command = "none";
    while (!command.equals("stop")) {
      if (client.available() > 0) {
        command = client.readString();
        command.trim();
        Serial.println(command);
        if ( command.equals("back") ) {
          rearWheels->setSpeed(255);
          rearWheels->run(BACKWARD);
        else if (command.equals("forward") ) {
        else if ( command.equals("brake") ) {
        else if ( command.equals("left") ) {
          frontWheels->setSpeed(150);
        else if ( command.equals("right") ) {
          frontWheels->run(BACKWARD);
    client.stop();
And my C# code just incase
Code: [Select]
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Net;
using System.Net.Sockets;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
namespace RCController
    public partial class Form1 : Form
        byte[] msg;
        byte[] bytes = new byte[256];
        Socket s = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
        public Form1()
            InitializeComponent();
        private void Form1_KeyDown(object sender, KeyEventArgs e)
            if (e.KeyCode == Keys.Down)
                msg = Encoding.UTF8.GetBytes("back");
                try
                    // Blocks until send returns.
                    int i = s.Send(msg);
                catch (SocketException z)
                    Console.WriteLine(z.Message);
            else if (e.KeyCode == Keys.Up)
                msg = Encoding.UTF8.GetBytes("forward");
                try
            else if (e.KeyCode == Keys.Left)
                msg = Encoding.UTF8.GetBytes("left");
                try
            else if (e.KeyCode == Keys.Right)
                msg = Encoding.UTF8.GetBytes("right");
                try
            else if (e.KeyCode == Keys.ShiftKey)
                msg = Encoding.UTF8.GetBytes("brake");
                try
        private void connexionToolStripMenuItem_Click(object sender, EventArgs e)
            IPAddress[] IPs = Dns.GetHostAddresses("192.168.240.1");
            s.Connect(IPs[0], 5678);
            msg = Encoding.UTF8.GetBytes("This is a test");
            try
        private void deconnexionToolStripMenuItem_Click(object sender, EventArgs e)
            msg = Encoding.UTF8.GetBytes("stop");
            try
            s.Disconnect(true);
Thank you for the help
AllSystemGO
You see anything wrong with the code Frederico?
cmaglie
I see that you put some debugging prints, may you post the output?
(both C# and Arduino)
C.
AllSystemGO
My problem isn't with the output of my command cause that works perfectly, my problem is with the 2 seconds delay between my soft and the arduino giving the command. I tried different approach in my arduino code like, changing from a string to convert to a Int and switching my if to a switch.. case and the effect is still there. I even tried changing my string to a char and the 2 seconds delay is always there.
PS: Something else that I tried is using telnet as my command giver instead of my c# program and the delay remains.
AllSystemGO
FYI : adding a delay at the end, delay(500); and even changing the Serial speed to 115200 didn't change a thing.
I'm running out of ideas, if anyone has something else to try let me know.
Thanks
federicofissore
We are deep diving into Bridge code. The bottle neck seems that readString. We'll keep you posted
federicofissore
#21
Oct 30, 2013, 10:33 am Last Edit: Oct 30, 2013, 10:41 am by Federico Fissore Reason: 1
Turned out it wasn't a Bridge issue, but rather how Stream::timedRead works
It waits 1 second after having received the last character
Modify your sketch this way
Code: [Select]
if (client) {
 client.setTimeout(5);
It should become nearly instantaneous.
Tuning timeout depends on the quality of your connection: if it's poor and the timeout is too short, you may end up with incomplete commands
AllSystemGO
I'll test this out as soon as I get home tonight. Thank you Frederico, you guys rock.
AllSystemGO
Hey Frederico,
   You were right, the bottleneck is with the readString. After putting setTimeout(5); everything works flawlessly.
I had a glitch when I tried it and I don't know if it's because of the change but the board stopped responding after the second command. All the lights on the board started to flash and even after rebooting I couldn't access it via WiFI. I had to connect it USB and push my scketch again.
It is ok now and since then I didn't get that problem again.
Thank you Frederico for your time.
cagiva
We built a similar project.  However, we installed an Android device onto a RC car to control it autonomously. Here is the preliminary result:
http://youtu.be/vkvkfcqEUkk
newbotuser
AllSystemGO , Can you please share your final code(Sketch)? I am having trouble controlling my car.
