Thank you...
I've created a database called "test1.db" at /mnt/sda1/arduino/test/www and i'm using this arduino code /*get time and pin1 and pin2 state and run a linux process on the linino server to write to database table
#include <Bridge.h>
#include <Process.h>
// how often to run the pin read (in milliseconds)
const unsigned long RUN_INTERVAL_MILLIS = 60000;
// the last time we ran the pin read (initialized to 60 seconds ago,
// so the pins are read immediately when we start up)
unsigned long lastRun = (unsigned long)-60000;
// variables for setting up time
Process date; // process used to get the date
String timeString;
// for debugging, wait until a serial console is connected. This can be removed after the code is debugged, along with all the Serial. commands
delay(4000);
while(!Serial);
Serial.print("Initializing the bridge...");
Bridge.begin();
Serial.println("OK");
// run an initial date process. Should return:
// hh:mm:ss :
if (!date.running()) {
date.begin("date");
date.addParameter("+%D +%T");
date.run();
Serial.println(date.readString());
}//end setup
// get the number of milliseconds this sketch has been running
unsigned long now = millis();
// run again if it's been RUN_INTERVAL_MILLIS milliseconds since we last ran
if (now - lastRun >= RUN_INTERVAL_MILLIS) {
// remember 'now' as the last time we checked the pins
lastRun = now;
// get the date and time
date.begin("date");
date.run();
}//end if
// put the date and time into a string variable
while (date.available()>0) {
timeString = date.readString();
}//end while
//get the pin states and add them to the database
String pin1 = String(getSensorValue(1));
String pin2 = String(getSensorValue(2));
runSqlQuery(timeString,pin1,pin2);
} //end if
}// end loop
// function to run the appending of the data to the database
unsigned int runSqlQuery(String time, String pin1, String pin2){
Process p;
String cmd = "sqlite3 ";
String paramstring1 = "-line ";
// set the path and name of your database here
String paramstring2 ="/mnt/sda1/arduino/www/test/test1.db ";
// insert a row with time and sensor data
String paramstring3 ="'insert into testdata (\"time\",\"pin1\",\"pin2\") Values (\""+time+"\","+pin1+","+pin2+");'";
// get the error code
String paramstring4 =" ; echo $?";
p.runShellCommand(cmd + paramstring1 + paramstring2 + paramstring3+ paramstring4);
Serial.println("process run");
// A process output can be read with the stream methods
while (p.available()>0) {
char c = p.read();
Serial.print(c);
// Ensure the last bit of data is sent.
Serial.flush();
//function to get sensor values with debugging information
int getSensorValue(int pinNum) {
Serial.print("Reading pin "+ String(pinNum)+ "value...");
int value = analogRead(pinNum);
return value;
but the table "testdata" is always empty....where did I go wrong?
