Topic: Yun and serial monitor issues - process example (Read 876 times) previous topic - next topic
NewLine
I have been trying the process example from the Yun getting started page (http://arduino.cc/en/Guide/ArduinoYun#toc18).
The previous examples all worked, but this one does not. Either something is wrong, or I am doing something wrong.
Very early in the example there is the code
Code: [Select]
// Wait until a Serial Monitor is connected.
  while (!Serial);
and I think it just gets stuck in that while loop.
I am currently running the following sketch:
Code: [Select]
#include <Process.h>
  // Initialize Bridge
  Bridge.begin();
  // Initialize Serial
  pinMode(13,OUTPUT);
  while (!Serial)
  digitalWrite(13,HIGH);
  delay(200);
  digitalWrite(13,LOW);
  delay(200);
and I see LED 13 blinking at the high blinking rate.
I had thought that if I would open the serial monitor, it would start flashing slower, but that does not happen.
Maybe I am opening the serial monitor incorrectly? In the arduino IDE I do: Tools --> Serial Monitor
When I do that I get an extra window, with at the top my Yun's IP address (192.168.1.7), but for the rest nothing. The baudrate in the monitor is set to 9600.
What am I doing wrong? Anyone else with a Yun that has gotten this (not) to work?
Thanks in advance,
Nico
NewLine
found it...works only when yun is connected via USB. Should better be mentioned on the getting started page.
