Topic: 10 Watt high power LEDs. (Read 7163 times) previous topic - next topic
cjdelphi
Oct 22, 2013, 08:08 am Last Edit: Oct 22, 2013, 08:15 am by cjdelphi Reason: 1
I can't find a data sheet on those 10watt LEDs but...
10watt / 3 LED's (to give a share of each)
=  3.3watts per share (3 watts Red, Green, Blue).
3 watts at 12v
Roughly 0.25amps per RGB.
I'm well aware of the current limiter, the current is slightly too high for a UNL transistor array IC, too low for use of a mosfet, so to hell with it (I've got a 2n2222 for each segment 15 NPN's each heatsinked), I have in total 5 - 10watt LEDs, I decided to take a risk and not use any current limiting (Except on base), collector/emitter side and use a 1-5k resistor on the base to limit the current (eg, 2k for RED, 1k for Blue 800ohms for Green), which is all done, then I adjust the PWM to lower the current (for in the warmer months) and increase the current for colder months, i'll use an NTC thermistor or something as "reference" if it does not go to plan.
I'm not asking for help, just telling you what's going on...
What I can't decide on, these 10watt LEDs, there's 3 LED's in series (3 forward voltage drops), if each of these little LED's must be 1watt each, giving 3watts per channel., I have a 300watt heatsink along with all the transistors mounted on the heatsink along with the LEDs...
This may fail spectacularly after 30 minutes of 50watts of current draw lol...  I have a large switching power supply raring to go...  So here goes, one monster RGB LED chaser lol...
Either way i'll take pictures :)
When done, I'll have it soldered up and I'll stick it outside somewhere.. (the pink LED in the background is barely drawing 80ma it's a 1watt LED) this LED bar (when running at full power) should make you see pretty stars for a while after viewing it....
TomGeorge
Hi, just looking at the pic, you may have to fit a fan to circulate air through the heatsink.
I looked at some LED lights for 240Vac application and they all had to have either some significantly finned heatsink and/or a cooling fan to keep their assemblies cool.
Tom.... :)
Everything runs on smoke, let the smoke out, it stops running....
cjdelphi
As i see it... the heatsink will do just fine.
each 2n2222 can deliver up to 400ma of current (using the resistors on a 23c day)
15 * 0.4
6 Amps Total Delivery.
or  72 watts (before PWM)
With PWM i'll get a balance between 50-60watts
the power supply....  240ac switch mode can supply 5amps at 12v  (60watts)
So Fine line, and i'll be doing this with 2n2222's ! (all plastered to the heatsink)
arduinodlb
Just curious: what are you making?
Do not IM me. I will not respond. Ask questions in the forum.
cjdelphi
A 50 watt RGB led mood lamp (flood lamp) ....
And an arduino :)
cjdelphi
http://www.youtube.com/watch?v=hj1XB8-_zGY
Here's the breadboard version and very dodgy connections, i'll ramp it up two - three x the power tomorrow when the paste fully sets.
rickso234
Those LED-to-LED transitions are rather harsh and could be softened up some... it's a mood lamp. Try slower PWM changes and if you're feeling adventurous, write a routine that cycles through the LEDs, remembering where each one was during the last cycle, so they're all lit to some extent at the same time but dim and brighten them on some pattern or randomly.
Headroom
You CANNOT lower the current draw using PWM. You limit the overall energy going into the LED, however, if the current exceeds that of the LEDs spec you may have already shortened the lifetime of the LEDs.
http://trippylighting.com
http://ledshield.wordpress.com/
cjdelphi
You are kidding......... right?
You CAN lower the current draw via pwm (i do so all the time)
May have damaged?.. i wish i could get the current draw high enough to damage them due the pwm signal!
Magicj
No, they are not kidding :)
Unless you are using a Constant Current Driver with a PWM dimming capability, you can only reduce the average current not the peak current via PWM. If the peak current exceeds the recommended maximum of the LED then you will do some damage.
cjdelphi
ughhhhh... for god sake! I have a limiting resistor on the base of each transistor!
- I was being sarcastic.. you ARE kidding.
Even IF it "stopped" and got a constant hit with 5v....  the MAX current draw is 400ma (yes I've DONE IT, i have it wired up that way)
Now, stop with the bs please, I know what i'm doing here.....
Headroom
If you are using current limiting resistors, then you will not damage the  LEDs. However the assessment that with PWM you can perhaps reduce average current but not peak current is still correct.
cjdelphi
I could not care less about controlling the current via PWM, as far as i'm concerned i'm trying to get as much current draw from PWM as possible.... I have everything heatsinked and works great, except I used a bad 74hc chip (never checked it first before soldering) the other half my circuit board works great :(
Headroom
I was merely pointing out that there was a technical inaccuracy in what you wrote and did want to point it out as it has been a misunderstand in more than one three/post on this forum. No reason to be defensive!
I am not sure I understand your problem not being able to draw enough current. You wrote in a post above that you are using current limiting resistors that will limit the current through the LEDs to 400mA. When you set the duty cycle of the PWM signal to 100% then the "switches" are on 100% of the time, thus you will draw these 400mA. If you want more current to flow you'd need to lower the value of the current  limiting resistors, or is there something I am missing ?
cjdelphi
I explained what i was doing...
The only current limiting is on the base. Got it now?
