Topic: Cheap small self contained microprocessor (Read 12520 times) previous topic - next topic
MichaelMeissner
I decided to make Christmas ornaments for my family using the Adafruit Neopixel ring (http://www.adafruit.com/products/1463), and I was wondering what are my options for a self contained chip set that can do a neopixel ring.  I would prefer to have the microprocessor come complete without major soldering needed, as I am not that good at soldering (hey, I'm mostly a software guy).
While the Gemma, Trinket, or Digispark would work fine, I was wondering if there were cheaper boards for a quantity 6 order from a North American seller.  I have an Uno R3 that I could use to do the programming for the chip.
I bricked my Trinket and Gemma, and so far I haven't been able to use the Adafruit bootloader restorer that runs on the Uno to restart them.  Right now, I am somewhat down on those two boards, and may go for the digispark (which is $1 more).
I do have a hardware ISP on order to reset the trinket/gemma, but since it is on a slow boat from China, I don't expect to get it before we start thinking about sending the gifts out.
int2str
The Digispark is an ATTiny85 with a voltage regulator.
If you have another Arduino (UNO maybe?) to do the programming, you can just use an ATTiny85 by itself. Maybe a DC-to-DC voltage regulator to hook up the battery.
That would require minimal soldering and money wise you could end up far under $3.
I'm a software guy and I can do that much soldering...
MichaelMeissner
Thanks.  As these are Christmas ornaments, I assumed I would power it via a USB charger cable that plugs into the wall socket, and not a battery.  Any particular place you would order the ATtiny85's from?
int2str
I like to order from Digikey. They ship within the US in very few days.
Part numbers:
ATTINY85-20PU-ND - ATTiny85, 8-pin DIP package ($1.29)
A100204-ND - 8-pin DIP socket ($0.29)
fungus
#4
Oct 28, 2013, 07:47 pm Last Edit: Oct 28, 2013, 08:04 pm by fungus Reason: 1
Arduino Pro Mini is pin-compatible with Arduino Uno and quite small (34mm*18mm):
Under $4 each on eBay: http://www.ebay.com/sch/i.html?_nkw=arduino+pro+mini   (half the price of a digispark!)
( nb. You'll also need an FTDI adapter to program them, eg.: http://www.ebay.com/itm/320907184616   )
Advanced Arduino
fungus
#5
Oct 28, 2013, 07:53 pm Last Edit: Oct 28, 2013, 07:58 pm by fungus Reason: 1
There's a new breed of Pro Minis on eBay that has ISP interface as well as FTDI.
Look for the boards with a double row of pins at one end by the reset button...the price is about the same as the old ones.
Advanced Arduino
MichaelMeissner
Thanks, though the US price isn't all that cheap ($6.75 on ebay for the old version, none of the US sellers seem to have the new one).  I can see cheaper china versions, but as I said, I don't want to order from China, given how long it takes the normal order, and the fact that my wife always pushes to ship early so we get reasonable priced shipping.
MichaelMeissner
Part numbers:
Ok, the problem I have with ordering with Digikey, Mouser, etc. is just the shear number of parts that they offer, it can be hard to narrow down what to buy.
Is there anything else besides the ATtiny85, DIP socket, and voltage regulator that I need?  Capacitors?  Resistors?  Etc.?
nickgammon
My hex uploader can upload any data to the AVR line of chips (like the 328, Tiny84, Tiny85 etc.).
http://www.gammon.com.au/forum/?id=11638
To simply replace a bootloader:
http://www.gammon.com.au/forum/?id=11635
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
MichaelMeissner
Thanks Nick.  If I go with that approach, I need to get a SD card reader for the Uno.
fungus
#10
Oct 28, 2013, 09:23 pm Last Edit: Oct 28, 2013, 09:29 pm by fungus Reason: 1
Still cheaper than a Digispark...or an hourly rate for soldering Tiny85s together.
Some of the sellers have a $3 shipping option. I usually get them in 7-10 days if I choose that (to Spain). Go through the auctions and look at "Shipping and Payments" to find sellers who do it, eg. This one: http://www.ebay.com/itm/140966034693
We're still in October. The slowest eBay shipping I've ever seen took about a month (YMMV).
If your buying a dozen or so I'm sure there's somebody on aliexpress who'll send them via. courier for a reasonable price and they'll arrive in two days. I've ordered LED strips from China on a Friday afternoon and they arrived on Monday morning.
Advanced Arduino
fungus
PCBs (perfboard)
Six-pin headers for ISP prigramming
0.1uF ceramic capacitors for decoupling
You don't need a voltage regulator if you're using a USB charger, they have built-in regulation.
Advanced Arduino
int2str
To keep the soldering to a minimum and the PCB size small, I would simply program the chips in a bread-board  and them plug them into the socket. Can also do the prototyping on the breadboard.
MichaelMeissner
I've had at least 3 ebay auctions that never showed up, and 1-2 that eventually showed up 2-3 months later.  So, while I will buy stuff I don't need immediately from China/Singapore/etc. I would buy anything that's critical, unless it is from a supplier I've used before and trust.
In terms of paying for faster shipping, for most things, it winds up roughly the same cost or cheaper, if I order from a US vendor and use the US post office than use the Chinese shipping options that claim to expedite the shipping (and there still is the customs lottery that seems to hold things up on a random basis).
fungus
Out of how many?
Yeah, I guess that makes sense if you live in the USA.  :)
(I don't live in the USA so US sellers aren't any faster for me ... they're just double/triple the price)
Advanced Arduino
