Topic: Problem with YunClient and long strings [solved] (Read 12143 times) previous topic - next topic
AlexandreB
Hello,
The -u option to run the Bridge solve the problem for me.   XD Thank you very much.
Code: [Select]
myYunClient.available() still give a list of not strictly decreasing numbers. Maybe it is the right behavior. But it is not a problem because the important thing is that the null return is correct.
So I can now correctly parse the response of the IoT server I use.
Regards
Alexandre
arduinoCoder
I would just like to confirm that this problem has been solved with the latest Yun image "out of the box".
