Topic: Arduino set clock arrays help (Read 5500 times) previous topic - next topic
mariusnet
Oct 30, 2013, 12:55 pm Last Edit: Oct 30, 2013, 01:05 pm by mariusnet Reason: 1
hello everyone
i`m trying to program my arduino to setup the clock but i-m getting stuck in to the arrays
can i have a small little help please?
the code is here:
Code: [Select]
#include <bv4618_I.h>
#include <Wire.h>
BV4618_I di(0x31,9); // 0x62 I2C address (8 bit)
const char kb[]={
 0xD7,0xee,0xde,0xbe,0xed,0xdd,0xbd,0xeb,0xdb,0xbb,0x7e,0x7D,0x7b,0x77,0xe7,0xb7};
//char key;
char year[4];
char month[2];
char day[2];
char hour[2];
char min[2];
int a = 0;
int m = 0;
int d = 0;
int h = 0;
int mi = 0;
void setup(){
 di.setdisplay(4,20);
 di.setkeycodes(kb);
 di.cls();
 di.cls();
 di.puts("display test");
 di.rowcol(1,1);
void loop(){
 setYear();
void setYear(){
 while (1){ // do forever
   if(di.keys()){
     char key=di.key();
     if(key > 9) key+='A'-10;
     else key+='0';
     year[a] = key;
      a++;
     if (a == 4){
     Serial.println(year);
     if (m == 0){
      month[m] = key;
             m++;
       if (m == 2){
         Serial.println(month);
         //key = 0;
       day[d] = key;
       d++;
       //Serial.println(day);
thank you
PaulS
Quote
What does this mean?
Why does setYear() contain an infinite loop that continuously tries to set the year?
What is a BV4618_I?
mariusnet
#2
Oct 30, 2013, 03:00 pm Last Edit: Oct 30, 2013, 03:58 pm by mariusnet Reason: 1
Hi Paul and thank you for reply.
At this stage I just want to set a 4 digits array and when this is done to go to the next one what will be a 2 digits array. The main project will have 4 main settings zones. I mean when you press A will be able to set the date/time. When you press B or C to set maximum temperature etc.
The bv4618_i is the i2c library for the byvac 4618 lcd + 4x4 keypad i2c controller.
Thank you
enanthate
You don't need a clock.
Paul, tell him.
Jr. Member. I'm allowed to make jokes now.
mariusnet
#4
Oct 30, 2013, 06:37 pm Last Edit: Oct 31, 2013, 10:25 am by mariusnet Reason: 1
No problem.
Them arrays can be usef for any settings anyway
I got the first array printed in serial but I never got the second one.
can i have some help on switch the cases? i don`t really know how to make them so ..
Code: [Select]
void loop(){
    if(di.keys()){
      char key=di.key();
      else key+='0';
      if (key == 'A'){
        SetTheCLock
//  setYear();
//  setMonth();
//  setDay();
//  setHour();
//  setMinute();
void setYear(){
    if(di.keys()){
      char key=di.key();
      else key+='0';
      year[a] = key;
       a++;
      if (a == 4){
void setMonth(){
    if(di.keys()){
      char key=di.key();
      else key+='0';
      month[m] = key;
       m++;
      if (m == 2){
void setDay(){
    if(di.keys()){
      char key=di.key();
      else key+='0';
      day[d] = key;
       d++;
      if (d == 2){
void setHour(){
    if(di.keys()){
      char key=di.key();
      else key+='0';
      hour[h] = key;
       h++;
      if (h == 2){
      Serial.println(hour);
void setMinute(){
    if(di.keys()){
      char key=di.key();
      else key+='0';
      minute[mi] = key;
       mi++;
      if (mi == 2){
PaulS
Code: [Select]
You have too many other problems to be worried about that, yet. You should start by putting every { on a new line, and using Tools + Auto Format. Well, at least you should try. Then, perhaps, you'd see that the setYear(), etc. functions are define IN the loop() function. Which clearly is not allowed.
mariusnet
well i have them on the loop just for testing the output.
PaulS
Quote
On the loop()?
Calling a function from in loop() is perfectly reasonable. Defining a function INSIDE loop() is not.
mariusnet
thank you for reply Paul
you mean defining my keypad in the loop?
i was trying all the ways and did not work so and my knowledge about c++ are minimal. to create a function i have to read 2 days on internet that`s the reason why i`m here you see
i was trying everything inlude the vectors like:
for(a=0;a<=4;a++)
{do{
     year[a] = key;
}while(!key);
for(m=0;m<=2;m++)
{do{
     day[m] = key;
}while(!key);
did not worked out for me so
what you will do on my case?
AWOL
Code: [Select]
for(a=0;a<=4;a++)
{do{
     year[a] = key;
}while(!key);
"year" is an array with four elements - it does not have an element [4].
mariusnet
there is defined at the begining
char year[4];
AWOL
Yes, that's a declaration of an array with four elements.
The valid indices of that array are 0, 1, 2, 3.
4 is not a valid index of that array.
mariusnet
yes and i`m confused now :)
you mean for(a=0;a<=3;a++)
can you example that for me please?
thank you for the reply, i have a beer for you on Dublin :)
AWOL
More usually
Code: [Select]
for(a = 0; a < 4; a++)
mariusnet
yes and when i press 1 2 3 4 the output is the output is this:
1
11
111
1111
1111
1111
1111
1111
2111
2211
2221
2222
3222
3322
3332
3333
3333
3333
3333
3333
4333
4433
4443
4444
and when i use :
      year[a] = key;
       a++;
      if (a == 4){
the output will be 1234 but i don`t know how to swap to set month you see
