Topic: Arduino DUE + SPI Pins Ethernet Shield (Read 6152 times) previous topic - next topic
f.schiano
Hi to everybody,
I managed to use a DAC MCP4922 with my Arduino DUE and now I would like to use also an ethernet shield.
At the moment to use the DAC I´m taking the SPI pins directly from the Arduino Board as in the following picture:
When I will plug in the Ethernet Shield those pins will be occluded.
I would like to know to what pins on the ethernet shield they will correspond.
Thanks in advance for your replies,
Fabrizio.
f.schiano
So, my question is:
where can I find the pins:
SCK
MOSI
When I connect the Ethernet shield to the Arduino DUE?
For the CS pin there is no problem because I can also use the pin 52 (the 10 is for the Ethernet shield and the 4 is for the SD Card)
Thanks in advance,
Fab.
tbit
As far as I know this is the only header where you can pick up the SPI pins but i could be wrong. They may be rerouted in software but I do not know this for sure (check STM user manual) .  I have developed a protoshield for the DUE to try and break these pins out but even this can be problematic  because of the height discrepancies between the male and female headers.
http://togglebit.net/2013/06/11/quick-note-on-the-spi-header-of-the-protoshield/
Dan - www.togglebit.net - Arduino DUE proto shields - Arduino DUE CAN shields
Palliser
Hello f.schiano,
dan@togglebit.net is right. SAM3X8E has only one SPI controller (SPI0) with 4 chip selects (CS0-CS3). Only SAM3X8H has 2 SPI controllers (SPI0/SPI1).
What I would recommend is to make the Ethernet shield and your DAC to share the SPI pins. In order to to that you will need to unsold and replace the SPI connector with a one that permits access to the SPI pins. Just a thought. Regards!
noblepepper
This is a gripe of mine with my Ethernet shield. It has to be on the top if you use other shields that connect with the SPI signals.
That said, it is hard to find the 2x3 connectors with long tails, the only ones I found were in proto shield kits. Does anyone know of a source in the U.S. ?
chriskner
Try: SamTec: SSW-103-03-F-D
I've used them once to build a pass-thru board with an Ethernet shield on top.
-Chris
gallegojm
tbit
@noblepepper you can find them on eBay
f.schiano
I will use an Arduino protoshield I think and I will take out the ICSP pins :)
