YES!!!
I've got the Yun to connect via WPA2 Enterprise and I'll include the steps I followed at the bottom of this post. Before getting to this, however, I think my setup is incomplete and could use some further guidance. Specifically, I do not know how to download a CA cert for the network I connect to. This doesn't seem to be necessary to make a connection, because I still connect, but these CA certs seem pretty standard, so I'm not sure what to do. Finally, I can only connect to my Yun by typing the numerical IP address, but not via
http://arduino.local; this has been an on-going issue for me, because I do not understand it. How can I connect to my Yun using the the numerical IP address, but then fail to connect via
http://arduino.local?Also, are all opkg packages installed to the Yun memory? Can (and should) any packages be installed to the sd card?
A way to have the Yun connect to WPA Enterprise; I hope this helps as a starting point for just one other soul:
0. This setup was preformed with the help of Windows box.
1. Connect the Yun to a computer via the micro USB. This is not only a good way to power the Yun, but also convenient to communicate with a virtual serial connection. Upload the sketch
File>Examples>Bridge>YunSerialTerminal from the Arduino IDE.
2. Place the Yun within range of a wireless network (or connected via ethernet) that does not require WPA Enterprise. Connect the Yun to this network.
3. Open PuTTY, select the
Serial from the radio buttons, and change the baud rate to
115200. The baud rate will be whatever was set in the
YunSerialTerminal sketch in the line
Serial.begin(####)
. Click the
Open button and a window will open. Press enter and the Linino spash screen should appear or at the very least a command line.
4. Install wpad with the opkg package manager, because wpad has the wpa-enterprise ability whereas wpad-mini, the default package in the Yun, does not. wpad-mini comes pre-installed and must be removed first.
opkg update
opkg remove wpad-mini
opkg install wpad
5. Confirm the installation with
opkg list-installed
6. Edit the
/etc/config/network file using the vi text editor. Add a new config section that looks like
config interface 'myNetwork'
option proto 'dhcp'
To start editing the file, from the command line enter
vi /etc/config/network
- Press 'i' to start editing text
- Press 'ESC' to stop editing text
- Type ':x' save changes and exit
- Type ':q' to exit
- Type ':q!' to exit without saving changes
7. Now, edit the
/etc/config/wireless file using vi again. I found my setup worked when I included only the following under the
config wifi-iface section. Also, some of these settings are network specific, so please adjust accordingly:
option device 'radio0'
option network 'myNetwork'
option mode 'sta'
option encryption 'mixed-wpa+aes'
option eap_type 'peap'
option ssid 'mySSID'
option identity 'myUsername'
option password 'myPassword'
8. Move the Yun into the range of the WPA Enterprise protected network. Restart the wireless interface of the Yun by entering the following command from the command line:
wifi
9. The Yun will output some text with details about the connection being made. Finally, confirm and discover the IP address assigned to the Yun using the command
ifconfig
. The output of this command will contain a section called
wlan0; the IP address can be found next to the text
inet.
Thanks for everyone's help!
