Topic: Toorum's Quest II - ATmega328P based retro video game with 256 color graphics (Read 26239 times) previous topic - next topic
ph77
Hi!
EDIT: new video with music and sound effects!
http://www.youtube.com/watch?v=sLvgW_zb6bQ
Visit my blog at http://petenpaja.blogspot.fi for schematic, source code and technical info!
I'm finally ready to show you a project I've been working on and off for several months. It's a 8-bit retro video game based on Arduino and ATmega328P. The project is not yet finished -- I'm working on music playback which is still missing on the video.
Attached images: titlescreen, arduino based proto version, final standalone hardware.
Features:
Tile graphics mode with sprites. Up to three sprites per scanline, unlimited number of sprites vertically. Display resolution 104x80 with 256 colors. NES controller support. 4 audio channels with triangle, pulse, sawtooth and noise waveforms.
Music is still work in progress and not present in this early video footage.
Video signal is generated by the microcontroller by outputting 8-bit RGB values. The program has been heavily optimized and written in assembler, so that the ATmega328 outputs a new pixel exactly every 6th clock cycle. RGB values are converted to NTSC composite signal by AD725 chip.
Audio is generated in software by mixing 4 waveforms together. This should allow C64 SID quality music once the playroutine is finalized and music is composed.
The game is fully playable and has 15 rooms.
Atmega328P has only so many bytes of memory, so several tricks are needed to squeeze everything into memory. For example room data is compressed in flash and inactive rooms use only 1 byte of RAM to store the state of objects when the player is not around.
I'll probably do a full write up with schematics when music is done if people are interested in this.
Credits:
Hardware & software by Petri Häkkinen
Graphics tiles by Antti Tiihonen
Titlescreen by Juho Salila
ph77
Thanks! I noticed you're working on something similar. It's interesting to compare different approaches to video signal generation :)
janost
My work was aimed at making the screen work for my VIC-20/C64 emulator but turned out to be a better TVout solution :)
Still going to use it for my emulator even if it will be released as a library.
I have looked into overclocking the ATmega8 to 32.2MHz for generating NTSC color straight without addon circuits.
It is possible with 32MIPS.
ph77
You don't need 32 Mhz for that. Linus Åkesson did it with 17.73447 MHz :)
Anyway, getting control of colors is difficult with bitbanging because it's impossible to finetune the necessary frequencies. One of the reason why I decided to use the AD725 chip.
Overclocking is an interesting subject because it makes it possible to have higher resolutions.
nickgammon
Very interesting. I've ordered some AD725 chips to try to do something like this.
Can you release the code please? I'd be interested to see how you got the video and sound throughput, plus game logic, in what is probably a tight amount of time.
fungus
Impressive...!
Advanced Arduino
nickgammon
How did you generate the 4FSC Clock Input at 14.318180 MHz? I see from the video you appear to have an oscillator on board. Is that all that is required, or is there more to it than that?
Would a simple 14.318 MHz crystal do? Or not? There seem to be plenty of those on eBay for like $10 for 100 of them.
ph77
Thanks for the interest and kind words! They make the endless hours spent on the project worthwhile :)
Nick, a crystal can't directly produce the needed frequency for the AD725. The chip needs a strong (buffered) clock signal. The AD725 datasheet has a reference schematic for the oscillator, or you can simply use a crystal oscillator like I did, although they are more expensive and maybe harder to find.
Sure I can release the source code. Just give me a few days to clean up the code and add the playback routine. The code is in a pretty messy state because of many optimizations and because I wanted to release the video as soon as possible.
Here's a few things worth mentioning to maybe get you an idea what's going on:
The hardest part was getting sprites to work. I had to painfully cycle count the scanline routine so that it fetches tile data and masks sprites on top of the scanline while outputting a pixel every 6 cycles. After pulling in tile indices from RAM and tile graphics from ROM, there is hardly any time left to do sprites...
Audio is double buffered, so that at the start of each scanline video generation routine pulls a byte from an audio buffer. An assembly routine mixes 4 audio channels and fills up another buffer during vblank. The buffers are swapped at vsync. Timing needs to be precise, otherwise pops and clicks can be heard.
Audio mix + game logic takes around 40 scanlines so it just fits to the vblank period. There is hardly any cycles left during screen refresh.
RobvdVeer
I'm very much impressed.
Still its magical what they did in the 80's with C64, only 1mhz (with the sid chip of course).
fungus
Are there any left at all? Surely at some point it's better to just take over completely. The cycles spent responding to interrupts and saving/restoring state could be used for audio mixing, etc.
Advanced Arduino
ph77
C64 also had a dedicated graphics chip, the VIC-II, which has 8 hardware sprites, for instance. The 6510 CPU alone is hardly powerful enough to produce a NTSC/PAL video signal.
ph77
Yes, I have thought about this idea, to output the video signal directly without interrupts. But then *everything* has to be timed to the video signal and it becomes a huge PITA. I agree that to get the last few cycles out of the MCU it's the only way...
janost
Its better to squeez all cycles out if during the active lines and run the game updates during inactive lines.
In my videoblaster it uses all of the CPU when outputing pixels on 200 lines and and nothing during 112 lines.
That equals to an AVR running at 6MHz and that is fast comparing to 6502s.
fungus
Probably equivalent to a 12MHz 6502.
Advanced Arduino
