Topic: Arduino Robot - wheels won't grip (Read 3708 times) previous topic - next topic
chrisotherwise
I've just started using my new Arduino robot, and am finding that the wheels are unable to grip on *any* surface. I've tried it on wood, lino, concrete, carpet. On all of them the wheels spin most of the time rather than gripping and driving the robot along. When they do grip they don't do so evenly and the robot moves in curves rather than straight lines. The wheels do appear to have a rubber rim on them so I'm mystified as to why this is happening.
Any insight/suggestions would be appreciated.
Chris1448
Picture's would really,really help here.
Plus other things like applied voltage,motor driver type,manufacturer..
chrisotherwise
It's Arduino's own robot - http://arduino.cc/en/Main/Robot. I'm not too sure what motor types it uses - although I'd have expected them to build in an appropriate one... Would a video of it not working be useful?
JimboZA
Quote
This is, after all, the Arduino Robot section of the forum, Chris  8)
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
TomGeorge
Hi, does the control of your motors include speed, too much speed will literally rip the wheels away from any surface it is trying to get traction on, ie like a dragster.
Try slower speed and that should help get traction.
Can you post a copy of your sketch that you are using?
Tom.... :)
Everything runs on smoke, let the smoke out, it stops running....
Chris1448
My bad... I was watching FOX when I dreamed that up. :smiley-fat:
Wheels slipping..laminate flooring ,waxed floors..
or just as  TomGeorge mentioned.. the wheels are being over powered.
JimboZA
Looking at the product page pics, although the wheels seem to have tread, they are more of a shiny plastic than rubber? Maybe you could try rough them up with sandpaper, or stretch an elastic band round each one?
zoomkat
You probably could add some traction to the wheels by coating the wheel treads with the below rubber cement (it is easy to remove). When dry the cement is soft and a high coefficient of friction. You could do the same gluing on strips of the below shelf liner making soft gripping treads for the wheels.
http://www.waresdirect.com/products/Office-Supply/Elmer%60s/No-Wrinkle259462?trackURL=froogle&gclid=CLqbjLvD8roCFcTm7Aod5G0AfQ
http://www.amazon.com/Grip-Shelf-Drawer-Liner-Black/dp/B000KFSOFI
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
SRS1
I am going to hazard a guess and say that maybe the casters are lifting the wheels off the surface.
joemcder
Quote
The castors should not be both on the ground at the same time.  Take a carefull look.
Slipping on concrete?  That is odd. Maybe the wheels are mounted too high.  The batteries should supply enough weight but you can always add a bit more ballast.
