Topic: unable to make the official example WiFiUdpNtpClient works on a WiFi Shield (Read 909 times) previous topic - next topic
changks
Hi -
I tried my best to update the firmware and tried to use the  example WiFiUdpNtpClient to obtain the real time from the Internet.
However, I cannot get the real time as other users reported in this forum.
Here is what I got:
Attempting to connect to SSID: Michael_wifi
Connected to wifi
SSID: Michael_wifi
IP Address: 192.168.0.55
signal strength (RSSI):-59 dBm
Starting connection to server...
0
0
0
0
0
all zeros...
Please help us on this. The information about this is limited, so I hope you could post or update the tutorial on the webpage!
Thanks,
Michael
johnwasser
Is your router set to pass UDP packets to port 2390 on your Arduino?
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
changks
Thanks. I've set the forwarding port for the ip of Arduino from 1 to 60000.
I'm still getting all zeros.
ibrahim123
Hi!
Did you solve your problem with reciving packages, because I'm also trying to run the same example but get only 0's.
