Topic: Arduino, ethernet shield, motorshield, hangs in position and stays there. (Read 1 time) previous topic - next topic
TheDigitalToaster
Hello everyone,
So I got an arudino with ethernet shield and motor shield. This is connected to my router and I control my motorshield over the wireless internet with VB. But sometimes when I use my arrow keys to control my motors the arduino just stays in that position. Like it just stays going forward and it doesn't stop untill I reset the arduino. Any sollutions for this?
Thanks in advance.
Arduino code:
Code: [Select]
// Declarations
#include <SPI.h>
#include <Ethernet.h>
// Wired configuration parameters
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0xD1, 0x4B };
unsigned char local_ip[] = {192,168,1,102}; // IP address of WiShield
unsigned char gateway_ip[] = {192,168,1,1}; // router or gateway IP address
unsigned char subnet_mask[] = {255,255,255,0}; // subnet mask for the local network
int E1 = 8;
int M1 = 9;
int E2 = 6;
int M2 = 7;
EthernetServer server(80);
//char buffer[20];
String buffer = "";
  pinMode(M1,OUTPUT);
  pinMode(M2,OUTPUT);
  Ethernet.begin(mac, local_ip);
  if (client)
    boolean currentLineIsBlank = true;
    while (client.connected())
      if (client.available())
        char c = client.read();
        Serial.print(c);
        switch (c) {
          case 'v':
                  digitalWrite(M1,HIGH);
                  digitalWrite(M2, HIGH);
                  analogWrite(E1, 255);   //PWM Speed Control
                  analogWrite(E2, 255);   //PWM Speed Control
          case 'a':
                  digitalWrite(M1,LOW);
                  digitalWrite(M2, LOW);
          case 'r':
          case 'l':
          case 's':
                  analogWrite(E1, 0);   //PWM Speed Control
                  analogWrite(E2, 0);   //PWM Speed Control
VB Code: (I think it crashes on the arduino side)
Code: [Select]
Imports System.Net.Sockets
Imports System.Text
Public Class Form1
    Dim tcpClient As New System.Net.Sockets.TcpClient()
    Dim networkStream As NetworkStream
    Dim KeyPressed As Integer
    Dim IP As Long
    Dim vooruit As Boolean = False
    Dim achteruit As Boolean = False
    Dim links As Boolean = False
    Dim rechts As Boolean = False
    Dim keyboard As New KeyBoardInput()
    Dim VLC As Process
    Dim er As Integer
    Public Sub New()
        ' This call is required by the designer.
        InitializeComponent()
    End Sub
    Private Sub StartVLC()
        Dim proc As New ProcessStartInfo()
        proc.FileName = My.Settings.Locatie
        proc.Arguments = "-vvv http://192.168.1.100:81/videostream.cgi?loginuse=admin&loginpas=admin " '--fullscreen"
        VLC = Process.Start(proc)
    End Sub
    Private Function Arduino_Connect(ByVal IP As String, ByVal Port As Integer) As Boolean
        Try
            tcpClient.Connect(IP, Port)
            networkStream = tcpClient.GetStream()
            If Not networkStream.CanWrite Or Not networkStream.CanRead Then
                tcpClient.Close()
                networkStream = Nothing
                Return False
            End If
            Return True
        Catch ex As Exception
            MessageBox.Show(ex.Message)
        End Try
        Return False
    End Function
    Private Sub Arduino_Write(ByVal Output As String)
        Try
            If Not IsNothing(networkStream) Then
                Dim sendBytes As [Byte]() = Encoding.ASCII.GetBytes(Output)
                Dim endByte As [Byte]() = {&HFE}
                networkStream.Write(sendBytes, 0, sendBytes.Length)
                'networkStream.Write(endByte, 0, 1)
                er = 0
            Else
                If er < 1 Then
                    System.Threading.Thread.Sleep(10000)
                Else
                    MsgBox("ERROR")
                    er = er + 1
                End If
            End If
            Arduino_Disconnect() 'De arduino kant crasht en connectie valt weg :/
            Arduino_Connect("192.168.1.102", 80)
            Arduino_Write("s")
        End Try
    End Sub
    Private Sub Form1_load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        If My.Settings.Locatie = "" Then 'Als de string nog leeg is kennen we de locaatie van VLC niet en starten we form2
            Me.Hide()
            Form2.ShowDialog()
            Me.Show()
        End If
        Try
            StartVLC()
            keyboard.RegisterKey(Keys.Up)
            keyboard.RegisterKey(Keys.Down)
            keyboard.RegisterKey(Keys.Left)
            keyboard.RegisterKey(Keys.Right)
            AddHandler keyboard.KeyChanged, AddressOf KeyChanged
            keyboard.StartPolling()
            Timer1.Start()
        End Try
    End Sub
    Private Sub Arduino_Disconnect()
            tcpClient.Close()
        End If
    End Sub
    Private Sub KeyChanged(ByVal sender As Object, ByVal e As KeyEventArgs)
        If Not e.Pressed Then
            Arduino_Write("s")
        Else
            If e.Key.Equals(Keys.Up) Then
                Arduino_Write("v")
            ElseIf e.Key.Equals(Keys.Down) Then
                Arduino_Write("a")
            ElseIf e.Key.Equals(Keys.Left) Then
                Arduino_Write("l")
            ElseIf e.Key.Equals(Keys.Right) Then
                Arduino_Write("r")
            End If
        End If
    End Sub
    Private Sub ButtonDown(ByVal sender As Object, ByVal e As EventArgs) Handles Button1.MouseDown, Button2.MouseDown, Button3.MouseDown, Button4.MouseDown
        If sender.Equals(Button1) Then
            Arduino_Write("v")
        End If
        If sender.Equals(Button2) Then
            Arduino_Write("l")
        End If
        If sender.Equals(Button3) Then
            Arduino_Write("a")
        End If
        If sender.Equals(Button4) Then
            Arduino_Write("r")
        End If
    End Sub
    Private Sub ButtonUp(ByVal sender As Object, ByVal e As EventArgs) Handles Button1.MouseUp, Button2.MouseUp, Button3.MouseUp, Button4.MouseUp
        Arduino_Write("s")
    End Sub
    Private Sub Timer1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer1.Tick
        If VLC.HasExited Then
            Me.Close()
        End If
    End Sub
    Private Sub Panel1_Paint(ByVal sender As System.Object, ByVal e As System.Windows.Forms.PaintEventArgs)
    End Sub
End Class
