Topic: Arduino Resetting Itself with Relay (Read 13692 times) previous topic - next topic
askduino
Nov 22, 2013, 01:01 am Last Edit: Nov 22, 2013, 01:14 am by askduino Reason: 1
Hello,
I am using an arduino mega 2560 with ethernet shield, to control an 8 channel relay http://www.amazon.com/SainSmart-8-CH-8-Channel-Relay-Module/dp/B0057OC5WK. Everything works perfect, except when I turn on OR off a 25w AC fan connected to the relay, the arduino resets itself. This doesn't happen everytime, but about 80% of the time, I think this has something to do with the fan(motor) being an inductive load, but I'm not entirely sure. Once the fan has been turned on, it has no issue running, I also have no issue controlling other lighting devices of higher wattages connected to the relay.
A 12v 30A power supply is powering the arduino, along with 4 N-Channel mosfets connected to 4 LED strips. The coils of the relay is powered by a 5v 30A external power supply, and configured to use opto-isolation, whereby the jumper is removed between jd-vcc and vcc, and jd-vcc and ground are connected to external power supply. The relay driver vcc and input pins are connected to the arduino +5v and output pins respectively. The output pins of the arduino are also controlling the gate of the mosfets. To stabilize the current/voltage, I have also placed one 2200uf capacitor on the 5v and 12v rails of the power supply.
From what I see the relay board itself already have flyback diodes to protect from voltage spikes caused by inductive loads? I've spent hours trying to search for a solution, but can't seem to find it. Is there a way to fix this or do I need to get a solid state relay specifically for the fan? Thanks in advance.
Chagrin
Just to verify, from the Arduino to the relay board you're only connecting VCC and the relay IO pins (no GND)?
FYI, the diodes on the relay board are there to protect from the EMF spike caused by de-energizing the relay coil. They do nothing with respect to EMF spikes from, in your case, the fan. Hopefully someone else will comment on that.
askduino
Hi Chagrin, that is absolutely correct.
Oh ok, appreciate the enlightenment, hopefully more help follows.
nilton61
Putting a small capacitor and/or a varistor(both appropriate rated)  across the relay  contact (not the coil) might help.
dc42
The capacitor needs to be rated for AC use to a voltage at least as high as your mains voltage. Also it should have a resistor in series with it. This arrangement is called a snubber. It can be connected either across the relay contacts or across the fan. It's hard to suggest values without knowing more about the fan, but for 230V mains, 0.1uF in series with 100 ohms might be a good place to start. For 110V mains I would double the capacitor value and halve the resistor.
Formal verification of safety-critical software, software development, and electronic design and prototyping. See http://www.eschertech.com. Please do not ask for unpaid help via PM, use the forum.
askduino
Thank you for the replies, I don't currently have a high voltage capacitor on hand at the moment. I will try it once I get my hands on one. For the resistor, I guess I will need to find one that supports more than 25w as well.
dc42
No, however the resistor must be capable of tolerating the peak mains voltage for very short periods. A 0.5W or 1W metal film resistor will do.
askduino
All right, I will post back the results once I get hold of the parts and test it. Appreciate the help.
askduino
Thanks dc42, just managed to hook up the parts with the values you provided to create the RC snubber and it works perfectly, absolutely no more resets when turning on or off the fan. It is very stable now.
Hopefully this will help someone else with the issue with inductive load when using it with a relay.
dc42
Thanks fro reporting back - I'm glad you got it working!
jnmbk
I think I'm having the same problem here. I'm trying to control two 220V motors with the very same 5V relays in the picture. And Arduino sometimes reset when two motors are stopped at the same time.
I want to try this RC snubber but I got confused when I saw the image askduino posted. Do I need to connect this parallel to the coil (220v part), or serial?
756E6C
The snubber should go across the relay terminals, wouldn't hurt to have a 300 volt varistor across the motor leads.
Thomen
Hi I have a similar relay operating a 12v pump my arduino resets when it shuts off.. I was hoping to learn how to work out which parts I need to use to create a snubber.. my relay has the 12v power source + the positive terminal of the pump I'm running in it.. so would I connect the snubber across those 2 lines?
Wawa
For inductive DC loads, use a diode across the pump.
Cathode (ring) to +12volt.
The diode has to match the current rating of the pump.
Leo..
BryanX
Hello,
I am facing the same issue with switching off aquarium water pump with relay. Thinking of buying the rc snubber from this aliexpress vendor. Is it suitable and how do I connect it to the relay?
https://www.aliexpress.com/item/Free-Shipping-Solenoid-inductive-load-RC-circuit-snubber-circuit-relay-contact-protection-Electronic-Component/1000001965161.html
Please help.
Thanks
