Topic: Signature error while burning bootloader onto ATMEGA328P-PU using ISP (Read 2309 times) previous topic - next topic
inleo
Hello,
I am trying to burn bootloader onto a fresh ATMEGA328P-PU using arduinoISP.  I am using 16Mhz external crystal.
I have followed all the instruction described in this link.
http://www.instructables.com/id/Burning-the-Bootloader-on-ATMega328-using-Arduino-/?ALLSTEPS
But it gets error :
avrdude: Expected signature for ATMEGA328 is 1E 95 14    Double check chip, or use -F to override this check.
I am confused if the board description is correct or not.
Please help.
Thank you.
westfw
The instructable is about how to put the bootloader into a (mistakenly purchased) ATmega328 chip, instead of the ATmega328P chip that is the usually used chip (and which you appear to have.)  So you actually need a simpler set of instructions, and need to use "atmega328p" in all the places that you need to provide a processor type.
Try Nick Gammon's tools and tutorial: http://www.gammon.com.au/forum/?id=11637
