Topic: ArduinoRobot.h and Wire.h (Read 6583 times) previous topic - next topic
kihon38
Hello,
I´m trying to compile a project with theses tow libraries <ArduinoRobot.h> and <Wire.h> but doesn,t work. I don´t know if there is any incompability with these libraries.
Thanks in advance.
Angel
TomGeorge
Hi, how does it not work, compilation error or after upload an output problem?
What version of adruino IDE are you using?
Tom... :)
Everything runs on smoke, let the smoke out, it stops running....
kihon38
Hi, my IDE version is 1.5.4 and when i try to use both libraries I have a lot of errors in the compilation. I have done many test and only writing #include <ArduinoRobot.h> and #include<Wire.h> the project give me errors. If I delete one of them (Robot or wire) and its code the proyect works.
Thanks.
kihon38
Hi, today I´ve been another test and also I have the same problem. In this case I used <ArduinoRobot.h> and <Sevo.h> a"Impossible to complie. this is the error:
avr\Servo.cpp.o: In function `__vector_17':
D:\Arduino\libraries\Servo\arch\avr/Servo.cpp:78: multiple definition of `__vector_17'
avr\Melody.cpp.o:D:\Arduino\libraries\Robot_Control\arch\avr/Melody.cpp:7: first defined here
Angel.
TomGeorge
Hi can you post your code using the code tags and we will see if there is a conflict, how have you developed this sketch, a part at a time or tried to write it all at once.
Tom..... :)
E40racer
The ArduinoRobot.h library already includes the wire library: http://arduino.cc/en/Reference/RobotLibrary
www.bajdi.com
kihon38
hi, this is the code, it is very simple because I have the robot one week ago.
#include <Servo.h>
int trigger = D3;
int echo = D5;
double distance;
    Robot.begin();
    //Serial.begin(9600);
    pinMode(trigger,OUTPUT);
    pinMode(echo,INPUT);
   Robot.motorsWrite(100,100);
   Robot.digitalWrite(trigger, LOW);
   delayMicroseconds(2);
   Robot.digitalWrite(trigger, HIGH);
   delayMicroseconds(5);
   distance=pulseIn(echo,HIGH);
   distance=(distance/29)/2;
   //Serial.println(distance);
   if (distance<30)Robot.motorsStop();
   else Robot.motorsWrite(100,100);
      delay(100);
When I delete the Servo library I can compile.
Thankss  :)
Angel
TomGeorge
Hi Angel, I think
Code: [Select]
int trigger = D3;
int echo = D5;
should be
Code: [Select]
int trigger = 3;
int echo = 5;
I don't have the arduinorobot library for some reason, so when I get it I'll try and get it to compile.
Tom.... :)
hockwei
Hi guys:
I needed to assess the I2C pins on the Arduino robot control board, from the website (http://arduino.cc/en/Reference/RobotLibrary ) I understand that the "Wire" library is already included in the arduinoRobot.h. But the problem is what are the equivalent commands? e.g. what is the equivalent of "Wire.requestFrom(2, 6)"?
Appreciate if anyone could give me some guidance.
Best Wishes,
Sean
LMSimarroG
Hi, I have also problems compiling Arduino robot sketches...I think the library Arduinorobot.h doesn't work. The error is: "Error Compiling" I have Arduino 1.0.6. How can I get this library and run all those arduino robots sketches?
Thank you
LM Simarro
AadilMogal
Tom... :)
Sir, I too have a similar problem... when i use ArduinoRobot.h library in any program it never gets compiled.... I am using vetsion 1.6.7 . Please reply... what should i do...eve the examples could not be compiled...please reply.
@ mughalaadil@gmail.com
