Topic: Avrdude: verification error. Help! (Read 20317 times) previous topic - next topic
dantedraven13
Hi All,
I was trying to upload a bit of code and got this error:
Code: [Select]
avrdude: verification error, first mismatch at byte 0x0086
         0x04 != 0x44
I'm still very new to arduino and have no idea how to fix this. I've searched the forum and found nothing helpful other than it might need to be told to wipe the previous code before uploading the new code and isn't, which is causing the problem. Is this the case and if so, how can I solve it? I know the code I'm uploading is fine and working as I have uploaded it to another board and it works fine.
Thanks in advance!
Jack
Coding Badly
dantedraven13
Hi Coding Badly,
Thanks for moving my post, I'm still finding my way around on here!
Its an Arduino Uno board. I've got three of them and the code works fine on the other two but I need them for other projects so I really need to find out whats wrong with this one  :smiley-sad-blue:
Thanks again,
Jack
Coding Badly
Post the verbose output.  Please use [code] [/code] tags.
dantedraven13
Hi Coded Badly,
Is this what you mean?
Code: [Select]
Binary sketch size: 5,020 bytes (of a 32,256 byte maximum)
         0x04 != 0x44
avrdude: verification error; content mismatch
Or something else? Sorry, I'm not the best at this.
Thanks again,
Jack
dantedraven13
Hi Coding Badly,
Sorry, got what you wanted.
PART 1:
Code: [Select]
Binary sketch size: 466 bytes (of a 32,256 byte maximum)
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P/dev/tty.usbmodem1421 -b115200 -D -Uflash:w:/var/folders/68/t83q_vns5k36c1k18pzd08pc0000gp/T/build1433395646767163271.tmp/sketch_dec04a.cpp.hex:i
avrdude: Version 5.11, compiled on Sep  2 2011 at 18:52:52
        Copyright (c) 2007-2009 Joerg Wunsch
        System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
        User configuration file is "/Users/jacktomkins/.avrduderc"
        User configuration file does not exist or is not a regular file, skipping
        Using Port                    : /dev/tty.usbmodem1421
        Using Programmer              : arduino
        Overriding Baud Rate          : 115200
avrdude: Send: 0 [30]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
        AVR Part                      : ATMEGA328P
        Chip Erase delay              : 9000 us
        PAGEL                         : PD7
        BS2                           : PC2
        RESET disposition             : dedicated
        RETRY pulse                   : SCK
        serial program mode           : yes
        parallel program mode         : yes
        Timeout                       : 200
        StabDelay                     : 100
        CmdexeDelay                   : 25
        SyncLoops                     : 32
        ByteDelay                     : 0
        PollIndex                     : 3
        PollValue                     : 0x53
        Memory Detail                 :
                                 Block Poll               Page                       Polled
          Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
          eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
          flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
          lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
          signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
        Programmer Type : Arduino
        Description     : Arduino
avrdude: Send: A [41] . [80]   [20]
avrdude: Recv: . [03]
avrdude: Send: A [41] . [81]   [20]
avrdude: Recv: . [04]
avrdude: Send: A [41] . [82]   [20]
avrdude: Send: A [41] . [98]   [20]
        Hardware Version: 3
        Firmware Version: 4.4
avrdude: Send: A [41] . [84]   [20]
avrdude: Send: A [41] . [85]   [20]
avrdude: Send: A [41] . [86]   [20]
avrdude: Send: A [41] . [87]   [20]
avrdude: Send: A [41] . [89]   [20]
        Vtarget         : 0.3 V
        Varef           : 0.3 V
        Oscillator      : 28.800 kHz
        SCK period      : 3.3 us
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00]   [20]
avrdude: Send: E [45] . [05] . [04] . [d7] . [c2] . [00]   [20]
avrdude: Send: P [50]   [20]
avrdude: AVR device initialized and ready to accept instructions
Reading | avrdude: Send: u [75]   [20]
avrdude: Recv: . [14] . [1e] . [95] . [0f] . [10]
################################################## | 100% 0.00s
Thanks again,
Jack
dantedraven13
PART 2:
Code: [Select]
avrdude: Device signature = 0x1e950f
avrdude: Send: V [56] . [a0] . [03] . [fc] . [00]   [20]
avrdude: Recv: . [00]
avrdude: Send: V [56] . [a0] . [03] . [fd] . [00]   [20]
avrdude: Send: V [56] . [a0] . [03] . [fe] . [00]   [20]
avrdude: Send: V [56] . [a0] . [03] . [ff] . [00]   [20]
avrdude: reading input file "/var/folders/68/t83q_vns5k36c1k18pzd08pc0000gp/T/build1433395646767163271.tmp/sketch_dec04a.cpp.hex"
avrdude: writing flash (466 bytes):
Writing | avrdude: Send: U [55] . [00] . [00]   [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [0c] . [94] 4 [34] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] d [64] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [11] $ [24] . [1f] . [be] . [cf] . [ef] . [d8] . [e0] . [de] . [bf] . [cd] . [bf] . [11] . [e0] . [a0] . [e0] . [b1] . [e0] . [e2] . [ed] . [f1] . [e0] . [02] . [c0]   [20]
#############avrdude: Send: U [55] @ [40] . [00]   [20]
avrdude: Send: d [64] . [00] . [80] F [46] . [05] . [90] . [0d] . [92] . [a0] 0 [30] . [b1] . [07] . [d9] . [f7] . [11] . [e0] . [a0] . [e0] . [b1] . [e0] . [01] . [c0] . [1d] . [92] . [a9] 0 [30] . [b1] . [07] . [e1] . [f7] . [0e] . [94] U [55] . [00] . [0c] . [94] . [e7] . [00] . [0c] . [94] . [00] . [00] . [08] . [95] . [08] . [95] . [cf] . [93] . [df] . [93] . [0e] . [94] . [ac] . [00] . [0e] . [94] S [53] . [00] . [c0] . [e0] . [d0] . [e0] . [0e] . [94] T [54] . [00]   [20] . [97] . [e1] . [f3] . [0e] . [94] . [00] . [00] . [f9] . [cf] . [1f] . [92] . [0f] . [92] . [0f] . [b6] . [0f] . [92] . [11] $ [24] / [2f] . [93] ? [3f] . [93] . [8f] . [93] . [9f] . [93] . [af] . [93] . [bf] . [93] . [80] . [91] . [04] . [01] . [90] . [91] . [05] . [01] . [a0] . [91] . [06] . [01] . [b0] . [91] . [07] . [01] 0 [30] . [91] . [08] . [01] . [01] . [96] . [a1] . [1d] . [b1] . [1d] # [23] / [2f] - [2d] _ [5f] - [2d] 7 [37]   [20] . [f0]   [20]
##############avrdude: Send: U [55] . [80] . [00]   [20]
avrdude: Send: d [64] . [00] . [80] F [46] - [2d] W [57] . [01] . [96] . [a1] . [1d] . [b1] . [1d]   [20] . [93] . [08] . [01] . [80] . [93] . [04] . [01] . [90] . [93] . [05] . [01] . [a0] . [93] . [06] . [01] . [b0] . [93] . [07] . [01] . [80] . [91] . [00] . [01] . [90] . [91] . [01] . [01] . [a0] . [91] . [02] . [01] . [b0] . [91] . [03] . [01] . [01] . [96] . [a1] . [1d] . [b1] . [1d] . [80] . [93] . [00] . [01] . [90] . [93] . [01] . [01] . [a0] . [93] . [02] . [01] . [b0] . [93] . [03] . [01] . [bf] . [91] . [af] . [91] . [9f] . [91] . [8f] . [91] ? [3f] . [91] / [2f] . [91] . [0f] . [90] . [0f] . [be] . [0f] . [90] . [1f] . [90] . [18] . [95] x [78] . [94] . [84] . [b5] . [82] ` [60] . [84] . [bd] . [84] . [b5] . [81] ` [60] . [84] . [bd] . [85] . [b5] . [82] ` [60] . [85] . [bd] . [85] . [b5] . [81] ` [60] . [85] . [bd] . [ee] . [e6] . [f0] . [e0] . [80] . [81] . [81] ` [60] . [80] . [83] . [e1] . [e8] . [f0] . [e0]   [20]
##############avrdude: Send: U [55] . [c0] . [00]   [20]
avrdude: Send: d [64] . [00] R [52] F [46] . [10] . [82] . [80] . [81] . [82] ` [60] . [80] . [83] . [80] . [81] . [81] ` [60] . [80] . [83] . [e0] . [e8] . [f0] . [e0] . [80] . [81] . [81] ` [60] . [80] . [83] . [e1] . [eb] . [f0] . [e0] . [80] . [81] . [84] ` [60] . [80] . [83] . [e0] . [eb] . [f0] . [e0] . [80] . [81] . [81] ` [60] . [80] . [83] . [ea] . [e7] . [f0] . [e0] . [80] . [81] . [84] ` [60] . [80] . [83] . [80] . [81] . [82] ` [60] . [80] . [83] . [80] . [81] . [81] ` [60] . [80] . [83] . [80] . [81] . [80] h [68] . [80] . [83] . [10] . [92] . [c1] . [00] . [08] . [95] . [f8] . [94] . [ff] . [cf]   [20]
######### | 100% 0.08s
dantedraven13
PART 3:
Code: [Select]
avrdude: 466 bytes of flash written
avrdude: verifying flash memory against /var/folders/68/t83q_vns5k36c1k18pzd08pc0000gp/T/build1433395646767163271.tmp/sketch_dec04a.cpp.hex:
avrdude: load data flash data from input file /var/folders/68/t83q_vns5k36c1k18pzd08pc0000gp/T/build1433395646767163271.tmp/sketch_dec04a.cpp.hex:
avrdude: input file /var/folders/68/t83q_vns5k36c1k18pzd08pc0000gp/T/build1433395646767163271.tmp/sketch_dec04a.cpp.hex contains 466 bytes
avrdude: reading on-chip flash data:
Reading | avrdude: Send: U [55] . [00] . [00]   [20]
avrdude: Send: t [74] . [00] . [80] F [46]   [20]
avrdude: Recv: . [0c] . [94] 4 [34] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] d [64] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [0c] . [94] Q [51] . [00] . [11] $ [24] . [1f] . [be] . [cf] . [ef] . [d8] . [e0] . [de] . [bf] . [cd] . [bf] . [11] . [e0] . [a0] . [e0] . [b1] . [e0] . [e2] . [ed] . [f1] . [e0] . [02] . [c0]
avrdude: Recv: . [05] . [90] . [0d] . [92] . [a0] 0 [30] . [f1] . [07] . [d9] . [f7] . [11] . [e0] . [a0] . [e0] . [b1] . [e0] . [01] . [c0] . [1d] . [92] . [a9] 0 [30] . [f1] . [07] . [e1] . [f7] . [0e] . [94] U [55] . [00] . [0c] . [94] . [e7] . [00] . [0c] . [94] . [00] . [00] . [08] . [95] . [08] . [95] . [cf] . [93] . [df] . [93] . [0e] . [94] . [ac] . [00] . [0e] . [94] S [53] . [00] . [c0] . [e0] . [d0] . [e0] . [0e] . [94] T [54] . [00]   [20] . [97] . [e1] . [f3] . [0e] . [94] . [00] . [00] . [f9] . [cf] . [1f] . [92] . [0f] . [92] . [0f] . [b6] . [0f] . [92] . [11] $ [24] / [2f] . [93] ? [3f] . [93] . [8f] . [93] . [9f] . [93] . [af] . [93] . [bf] . [93] . [80] . [91] . [04] . [01] . [90] . [91] . [05] . [01] . [a0] . [91] . [06] . [01] . [b0] . [91] . [07] . [01] 0 [30] . [91] . [08] . [01] . [01] . [96] . [a1] . [1d] . [b1] . [1d] # [23] / [2f] - [2d] _ [5f] - [2d] 7 [37]   [20] . [f0]
avrdude: Recv: - [2d] W [57] . [01] . [96] . [a1] . [1d] . [b1] . [1d]   [20] . [93] . [08] . [01] . [80] . [93] . [04] . [01] . [90] . [93] . [05] . [01] . [a0] . [93] . [06] . [01] . [b0] . [93] . [07] . [01] . [80] . [91] . [00] . [01] . [90] . [91] . [01] . [01] . [a0] . [91] . [02] . [01] . [b0] . [91] . [03] . [01] . [01] . [96] . [a1] . [1d] . [b1] . [1d] . [80] . [93] . [00] . [01] . [90] . [93] . [01] . [01] . [a0] . [93] . [02] . [01] . [b0] . [93] . [03] . [01] . [bf] . [91] . [af] . [91] . [9f] . [91] . [8f] . [91] ? [3f] . [91] / [2f] . [91] . [0f] . [90] . [0f] . [be] . [0f] . [90] . [1f] . [90] . [18] . [95] x [78] . [94] . [84] . [b5] . [82] ` [60] . [84] . [bd] . [84] . [b5] . [81] ` [60] . [84] . [bd] . [85] . [b5] . [82] ` [60] . [85] . [bd] . [85] . [b5] . [81] ` [60] . [85] . [bd] . [ee] . [e6] . [f0] . [e0] . [80] . [81] . [81] ` [60] . [80] . [83] . [e1] . [e8] . [f0] . [e0]
avrdude: Send: t [74] . [00] R [52] F [46]   [20]
avrdude: Recv: . [10] . [82] . [80] . [81] . [82] ` [60] . [80] . [83] . [80] . [81] . [81] ` [60] . [80] . [83] . [e0] . [e8] . [f0] . [e0] . [80] . [81] . [81] ` [60] . [80] . [83] . [e1] . [eb] . [f0] . [e0] . [80] . [81] . [84] ` [60] . [80] . [83] . [e0] . [eb] . [f0] . [e0] . [80] . [81] . [81] ` [60] . [80] . [83] . [ea] . [e7] . [f0] . [e0] . [80] . [81] . [84] ` [60] . [80] . [83] . [80] . [81] . [82] ` [60] . [80] . [83] . [80] . [81] . [81] ` [60] . [80] . [83] . [80] . [81] . [80] h [68] . [80] . [83] . [10] . [92] . [c1] . [00] . [08] . [95] . [f8] . [94] . [ff] . [cf]
######### | 100% 0.06s
avrdude: verifying ...
        0xb1 != 0xf1
avrdude: Send: Q [51]   [20]
avrdude done.  Thank you.
dantedraven13
Sorry the Verbose output is in 3 parts, it was exceeding the 9500 character limit.
Thanks again,
Jack
dantedraven13
Hi All,
Could someone tell me how to reset the arduino to factory settings? I think its worth a try and might solve the issue.
Thanks again,
Jack
Coding Badly
Coding Badly
The closest thing is to re-burn the bootloader.  All you need is some wire and a second board.
Quote
I agree.
dantedraven13
Where did you buy it?
How old is it?
From Maplins Electronics about 4 or 5 months ago.
How would I got about doing that? I have a second board a can use.
dantedraven13
Hi Coding Badly,
I found an online tutorial for reinstalling the bootloader here:
https://www.sparkfun.com/tutorials/247
However, after doing this I get this message now:
Code: [Select]
Any ideas?
Coding Badly
Yeah.  Don't use that tutorial.  It's missing at least one important step and the wiring method is just plain stupid.
Give this one a try...
http://arduino.cc/en/Tutorial/ArduinoISP
