Topic: Unable to compile any code - gcc avr error (Read 6217 times) previous topic - next topic
nyaculak
I'm running Antergos Linux (a derivative of Arch Linux)  and installed the Arduino IDE via the arduino package from the AUR.  When I try to compile ANY code (even a blank sketch), I get the following error.
Code: [Select]
/usr/share/arduino/hardware/tools/avr/lib/avr/bin/ld: cannot find -lm
It seems that the Arduino IDE comes with its own tool suite, which includes gcc avr.  I can't find another post that shares this kind of error.
I'm at  a loss to correct this problem; I tried installing the beta version of arduino from the AUR (arduino-beta) to get version 1.5.5 of the IDE, but I get the same error when compiling.
Any help would be appreciated.
tf68
lib m is part of avr-libc, perhaps you need to install avr-libc separately.
You could also try the tarball (.tgz) package from the Arduino downloads area. It contains everything but a java runtime and will coexist with your package install. Just unzip it in your home dir and run the arduino script.
nyaculak
Thanks for the reply.  For documentation purposes, I would like to report that I found a solution elsewhere on the internet.  The following solution was posted on the arduino package page on the Arch Linux AUR.
Quote
The following patch solves the
/usr/share/arduino/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../avr/bin/ld: cannot find -lm
problem.
Replace the following part in PKGBUILD
package() {
cd "$srcdir/arduino-$pkgver"
# arduino excutable should accept arguments
with
package() {
# remove the provided avr-gcc tool chain, cause
# we will use the one provided by Arch
rm -r hardware/tools
The arduino IDE will now use the avr-g++ that comes as a makedependency of avr-libc.
Probably also a good idea to list avr-gcc as a proper dependency.
Why this works is explained by the file:
arduino-1.0.5/hardware/tools/readme.txt
in the original archive.
Honestly, this solution seems a little buggy to me, but oh well.
