Topic: Where to put EEPROM.write to save memory cycle (Read 2735 times) previous topic - next topic
bule
Hi guys,
First of all I wrote a program with gsm shield to turn on and off 4 relays.
It's working ok but I want to add storing relay state so if there is a power fail all relay can turn back in previous state.
So I put eeprom.read at first palce in loop(), but I am afraid if I put eeprom.write at the end of loop after function (recieve sms) end it will soon reach maximum eeprom write.
Is it true or I am wrong.
CrossRoads
If you are writing to EEPROM every pass thru loop, then yes, you will wear it out quickly.
If you store it only when a relay changes state, that will help a lot.
If you use a different address for each relay, that will help to extend the number of writes that can be achieved.
bule
Do you think is better to put eeprom.writes in function for every relay or for all at once?
CrossRoads
Takes 3.3mS to write an EEPROM address - for check pointing purposes,  I would store all 4 at once.
How often are you writing? There are "wear leveling" schemes you can follow to spread the writes over many addresses so you do not just wear 1 address out.
This application note discusses wear leveling in Flash, the same principals apply to EEPROM as well.
nickgammon
If you only write when the state changes (eg. every half hour) then it will take a long time to wear out.
If you space the address for each relay apart by 4 bytes then each relay will be in a different "page" of EEPROM.
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
bule
Here is my code:
Code: [Select]
#include <EEPROM.h>
// include the GSM library
#include <GSM.h>
// PIN Number for the SIM
#define PINNUMBER ""
// initialize the library instances
GSM gsmAccess;
GSM_SMS sms;
#define gsm 9
int addr = 0;
unsigned char pins = 0;
  gsmOn();
  // initialize serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println(F("SMS Messages Receiver"));
  // connection state
  boolean notConnected = true;
  // Start GSM connection
  while(notConnected)
    if(gsmAccess.begin(PINNUMBER)==GSM_READY)
      notConnected = false;
      Serial.println(F("Not connected"));
  sms.flush();  // delete all messages
  Serial.println(F("GSM initialized"));
  Serial.println(F("Waiting for messages"));
  // If there are any SMSs available()
  if (sms.available())
    RelaySMS();
    sms.flush();
    //Serial.println("MESSAGE DELETED");
void gsmOn()
  // Takes 30 seconds to complete
  digitalWrite(gsm, HIGH);   // turn the Phone on
  digitalWrite(gsm, LOW);
  delay(5000);
void RelaySMS()
  char c;
  c=sms.read();         // procitaj sms
  if (c=='1')         // ako je prvi znak 1 uradi sledece:
    txt(A3,A3);
  else if (c=='2')
    txt(A2,A2);
  else if (c=='3')
    txt(A1,A1);
  else if (c=='4')
    txt(A0,A0);
/*void allstate()
String txtmsg = "";
while(c=sms.read())
txtmsg += c;
//Serial.println("Sadrzaj sms-a:");
//Serial.println(txtmsg);
if (txtmsg.compareTo("status") == 0)
pinstate = digitalRead(A3);
sms.remoteNumber(remoteNumber, 10);
sms.beginSMS(remoteNumber);
sms.print(pinstate);
sms.endSMS();
void txt(int Relay, int pin)
  pinMode(Relay, OUTPUT);
  String txtmsg = "";
  int pinstate;
  char c;
  char remoteNumber[10];
  while(c=sms.read())
    txtmsg += c;
  Serial.println(F("Sadrzaj sms-a:"));
  if (txtmsg.compareTo("on") == 0)
    digitalWrite(Relay, HIGH);
  else if (txtmsg.compareTo("off") == 0)
    digitalWrite(Relay, LOW);
  else if (txtmsg.compareTo("status") == 0)
    pinstate = digitalRead(pin);
    sms.endSMS();
bule
I think I know how to put eeprom.write in void txt () but how to restore all four pins in Void setup () so in case of power loss i can restore to previous state.
Relays are used for starting up machines or heat system in house.
kf2qd
Returning to previous state can be problematic. Are these only controlling things that can't get people caught it them? WHat if conditions have changed and the previous state is not needed?
bule
I am putting these option only if there is very short power failing.
For example, man sand sms to turn off water pump, it's not my problem if he forget to turn it off. My only worry is what if he turn on heat pump and shortly after that there is power fail only on second. The heat pump will stay off and he wouldnt know about it.
I dont want to put electronic for power loss detection.
