I am using put on the MCU side and get on the CPU side.
What I put is a concatenation of fixed (max) length strings. E.g. the first character is an ID, the next 16 a command and the next 16 a value. Not all commands are 16 chars long. So it could be that what I put on the MCU side is:
AmyCommand\0\0\0\0\0\0\0myValue\0\0\0...
(ID is A, command = myCommand extended with \0 to 16 chars, value is myValue, etc..).
Now on the CPU side when I do a get I only receive AmyCommand. So it seems that although I did put 33 characters, what I get is limited to everything until the first \0.
Is this indeed the intention? It would mean I have to padd the command with somthing else than \0.
I would think the BridgeClass should know the length of each data in its store and return that, without interpreting the content of the data.
NewLine:
It is exactly what strncpy does. I think it is the most obvious filler.
Not for your case. The bridge is handling the stuff as C strings, and when handling your whole string, including the \0 as fillers, it will rightfully cut the transmission at the first \0.
Use a blank (or tab for that matter) and separate by white space on the receiving end...
