How would one make a circuit in astable mode so that it works with a laser pointer.
Requirements :
- When the beam is interrupted it needs to trigger the piezo.
- Alarm continues when the beam is complete again.
- We need to press a button / toggle a switch / turn power on/off to reset the alarm (turn the piezo off)
I've setup the 555 timer in astable mode and used a light resistive sensor to act as part of a voltage divider on an NPN transistor that powers the 555 timer. Obviously, when the beam is interrupted the alarm sounds, but as soon as the beam is again pointed to the photo resistor the alarm turns itself off. (as the timer is no longer being powered).
However I want the alarm to continue when the beam is re-established.
I noticed the following video where someone did a similar thing (555 timer in astable mode using a light resistive sensor acting as a switch).
http://www.youtube.com/watch?v=8BJ8TMnotCMHow would one hook something like that up ?
