Topic: Example of driving ADC and DAC from timer for regular sampling (Read 31131 times) previous topic - next topic
JulianLewis
I am working with the DUE timers, could you please tell me where you found the definitions you used in your code, the TcChannel structure, where is this structure defined ? Where is it documented ? Where are the hardware definitions coming from like PIOB and functions like pmc_enable_periph_clk . I am very sorry to ask such a dumb question but I simply can't seem to find the hardware description anywhere ? The code is a great example for understanding the timers, I just need the definitions to make it do what I want.
alnoor45
So what the wrong her :
error: base operand of '->' is not a pointer
alnoor45
 So what the meaning of this ''error: base operand of '->' is not a pointer'' and how I can fix it . :(  :(
chemsou
hi
i would like to realise acquisition of 3 analog signals at 1KHz ,with arduino DUE ,and I dont now how to do it .
thanks for advance
ard_newbie
To understand the examples of this thread, I suggest that you start by reading the Analog to Digital Converter and Timer Counters sections of Sam3x datasheet.
There are many ways to trigger the ADC controller at a 3 KHz frequency for 3 analog inputs resulting in a 1 KHz sampling of each analog input. One of them is a hardware trigger, as listed in table TRGSEL section 43.7.2 page 1333. Note that there is a typo in this table because ADC_TRIG5 equals to PWM Event Line 1.
Edit : If a TIOA is used to trigger ADC conversions, it is interesting to use TIOA2 (TC0 channel 2 = TC2) since TIOA2 is output on pin PA5 which is not broken out. So you keep broken out pins TIOA0 (PB25) and TIOA1 (PA2)  usable for other purposes.
adeel
I have used this code to successfully acquire the audio from a 2-wire intercom system and played it back using a audio amplifier.
Now on the same 2-wire system there is data present too, which again acquired( on A0 using ADC) using this code and shown on the oscilloscope at DAC output.
Now I would like to show the received data onto serial port ?
EpicFoodCartDestroyer
Code: [Select]
void dac_setup ()
  pmc_enable_periph_clk (DACC_INTERFACE_ID) ; // start clocking DAC
  DACC->DACC_CR = DACC_CR_SWRST ;  // reset DAC
  DACC->DACC_MR =
    DACC_MR_TRGEN_EN | DACC_MR_TRGSEL (1) |  // trigger 1 = TIO output of TC0
    (0 << DACC_MR_USER_SEL_Pos) |  // select channel 0
    DACC_MR_REFRESH (0x0F) |       // bit of a guess... I'm assuming refresh not needed at 48kHz
    (24 << DACC_MR_STARTUP_Pos) ;  // 24 = 1536 cycles which I think is in range 23..45us since DAC clock = 42MHz
  DACC->DACC_IDR = 0xFFFFFFFF ; // no interrupts
  DACC->DACC_CHER = DACC_CHER_CH0 << 0 ; // enable chan0
void dac_write (int val)
  DACC->DACC_CDR = val & 0xFFF ;
Hi, This might be long shot since this hasn't been posted on in a while, but I had a question regarding the "dac_write" function:
Section 44.6.4 of the SAM3A-Atmel documentation says: "Warning: Writing in the DACC_CDR register while TXRDY flag is inactive will corrupt FIFO data."
I was wondering why it's not necessary to implement some sort of check that prevents writing to the CDR when the the TXRDY flag is inactive.
Regards,
-H
ard_newbie
The DAC peripheral is much faster than the ADC peripheral:
Sam3x datasheet, Page 1403: Max ADC sampling frequency = 1 MHz
Sam3x datasheet, Page 1411: Max DAC sampling frequency = 2 MHz
BTW, to sample from one of the builtin ADC channels and output from one of the builtin DAC channels, the best option is to make use of the PDC DMA to divide by the buffer size the total number of interruptions  :)
Code: [Select]
pmc_enable_periph_clk (TC_INTERFACE_ID + 0*3+0) ;  // clock the TC0 channel 0
  TcChannel * t = &(TC0->TC_CHANNEL)[0] ;                // pointer to TC0 registers for its channel 0
  t->TC_CCR = TC_CCR_CLKDIS ;                                // disable internal clocking while setup regs
  t->TC_IDR = 0xFFFFFFFF ;                                        // disable interrupts
  t->TC_SR ;                                                              // read int status reg to clear pending
  t->TC_CMR = TC_CMR_TCCLKS_TIMER_CLOCK1 |      // use TCLK1 (prescale by 2, = 42MHz)
              TC_CMR_WAVE |                                         // waveform mode
              TC_CMR_WAVSEL_UP_RC |                         // count-up PWM using RC as threshold
              TC_CMR_EEVT_XC0 |                                // Set external events from XC0 (this setup TIOB as output)
              TC_CMR_ACPA_CLEAR | TC_CMR_ACPC_CLEAR |
              TC_CMR_BCPB_CLEAR | TC_CMR_BCPC_CLEAR ;
  t->TC_RC =  875 ;                                                // counter resets on RC, so sets period in terms of 42MHz clock
  t->TC_RA =  440 ;                                             //why 440???
  t->TC_CMR = (t->TC_CMR & 0xFFF0FFFF) | TC_CMR_ACPA_CLEAR | TC_CMR_ACPC_SET ;  // set clear and set from RA and RC compares
  t->TC_CCR = TC_CCR_CLKEN | TC_CCR_SWTRG ;  // re-enable local clocking and switch to hardware trigger source.
I am trying to output a 60Hz sinewave via a DMA. Would anyone be able to explain why TC_RA is set to 440?
In the attached code I have a 2000 point sinewave (I know it could have less points) I set TC_RC to 350 because the dac should output at a frequency of n*"desired hz"
However, when I ran the code with RA at 440 the dac did not output anything, when I  changed RA to 110 the DAC began to output.
ard_newbie
TC_RA = TC_RC/2 to output a 50% duty cycle. And TC_RA < TC_RC  !!
TUCTUC77
I am trying to use the sketch number 1, but actually I cannot have what there is on the pictures of the oscilloscope, can someone help me ?
ard_newbie
Post the sketch you are actually using (between code tags).
TUCTUC77
Thank you for your answer, actually I can have it but the signals seems to be in opposite phase
this is my code
Code: [Select]
//generation du Timer sampling a 1kHz
  adc_setup () ;         // setup ADC
  t->TC_RC =  42000 ;     // counter resets on RC, so sets period in terms of 42MHz clock
  t->TC_RA =  21000 ;     // roughly square wave
  setup_pio_TIOA0 () ;  // drive Arduino pin 2 at 48kHz to bring clock out
  dac_setup () ;        // setup up DAC auto-triggered at 48kHz
void setup_pio_TIOA0 ()  // Configure Ard pin 2 as output from TC0 channel A (copy of trigger event)
  PIOB->PIO_PDR = PIO_PB25B_TIOA0 ;  // disable PIO control
  PIOB->PIO_IDR = PIO_PB25B_TIOA0 ;   // disable PIO interrupts
  PIOB->PIO_ABSR |= PIO_PB25B_TIOA0 ;  // switch to B peripheral
void dac_setup()
  pmc_enable_periph_clk(DACC_INTERFACE_ID);            // start clocking DAC
  DACC->DACC_CR = DACC_CR_SWRST;                       // reset DAC
  DACC->DACC_MR =
    DACC_MR_TRGEN_EN | DACC_MR_TRGSEL(1) |             // trigger 1 = TIO output of TC0
    (24 << DACC_MR_STARTUP_Pos);                       // 24 = 1536 cycles which I think is in range 23..45us since DAC clock = 42MHz
  DACC->DACC_IDR = 0xFFFFFFFF;                         // no interrupts
  DACC->DACC_CHER = DACC_CHER_CH0 << 0;                // enable chan0
void adc_setup ()
  NVIC_EnableIRQ (ADC_IRQn) ;   // enable ADC interrupt vector
  ADC->ADC_IDR = 0xFFFFFFFF ;   // disable interrupts
  ADC->ADC_IER = 0x80 ;         // enable AD7 End-Of-Conv interrupt (Arduino pin A0)
  ADC->ADC_CHDR = 0xFFFF ;      // disable all channels
  ADC->ADC_CHER = 0x80 ;        // enable just A0
  ADC->ADC_CGR = 0x15555555 ;   // All gains set to x1
  ADC->ADC_COR = 0x00000000 ;   // All offsets off
  ADC->ADC_MR = (ADC->ADC_MR & 0xFFFFFFF0)| (1 << 1) | ADC_MR_TRGEN;   // 1 = trig source TIO from TC0\
// Circular buffer, power of two.
#define BUFSIZE 0x400
#define BUFMASK 0x3FF
volatile int samples [BUFSIZE] ;
volatile int sptr = 0 ;
volatile int isr_count = 0 ;   // this was for debugging
#ifdef __cplusplus
extern "C"
#endif
void ADC_Handler (void)
  if (ADC->ADC_ISR & ADC_ISR_EOC7)   // ensure there was an End-of-Conversion and we read the ISR reg
    int val = *(ADC->ADC_CDR+7) ;    // get conversion result
    samples [sptr] = val ;           // stick in circular buffer
    sptr = (sptr+1) & BUFMASK ;      // move pointer
    dac_write (0xFFF & ~val) ;       // copy inverted to DAC output FIFO
  isr_count ++ ;
#ifdef __cplusplus
#endif
this is exactly the same, just modifying the sampling rate...
ard_newbie
BTW, there is an interrupt after each and every conversion ( 1000 times per second). A more rational sampling method would be to fill a sampling buffer (e.g. 128 values), output this buffer thru a DAC while continuously sampling to fill another buffer with a PDC DMA thus dividing interrupts by a 128 scale.
https://forum.arduino.cc/index.php?topic=224672.0
reply 10
TUCTUC77
thank you for your reply, i did not saw the inversion, think i was tired.
About the other sketch, do you think it is really better, because this one works good and i only need a sampling frequency of 1k and the input is a sinewave of 100hz, i have the feeling that i can works with that sketch, no ?
