Topic: voltage drop on Pin3 duemillanueva (Read 666 times) previous topic - next topic
cjeung
Is there a reason why my output should drop to 0v, when I set the PWM output for Pin 3 to 100%, on the Duemillanueva?
Also, attached is a DFrobot LCD shield, but the pin 3 transfer output is fine until I reach Max output. Again, my output drops to 0 when I do this. I checked the same instance on pin 11 and it works fine.
please, excuse the duplication of this thread topic. I placed it in the troubleshooting section as well, not knowing exactly where to post it.. this forum is specific to pinouts.
CrossRoads
Duplicate post deleted.
Post your code - gotta be something funny set up.
Could be pin 3 was previously damaged somehow if 11 works.
5,6,9,10 all work okay? (I think those are the PWM pins).
What if you just take a HIGH from another pin?
cjeung
Thanks for the post reply.
I found the code error while looking for the code snippet to post
FYI, Had a typo in the PWM max setting (256 instead of 255)
Cheers
CrossRoads
